Elder, that is GODLY GORGEOUS
KetelOne I used a Sunbeam UV cathode (2 each) on top of the 800D.
Thats all,no any other lights.
http://img340.imageshack.us/img340/6628/p1120314.jpg
http://a.imageshack.us/img202/9592/p1010917w.jpg
Black and Black rev was not so long ago, with G.SKILL 2000MHz TRIDENT.
http://img202.imageshack.us/img202/2453/p1030473i.jpg
Thanks, I'm trying, trying ...
It's probably 4 rev in this case starting from April 2010.
http://forum.pclab.pl/topic/581684-O...-DARK-Project/
http://db.tt/Tb91QS8
http://db.tt/LwUQdzW
http://db.tt/OnoxAcl
http://db.tt/nfKmuGJ
http://db.tt/5heknvZ
http://db.tt/ay1CwIl
http://db.tt/K7X1bk0
http://db.tt/anubeEu
http://db.tt/EFabvRa
http://db.tt/5AAON5W
http://db.tt/7SauDWK
http://db.tt/wnwQN3z
http://db.tt/1AQ7bkL
http://db.tt/OKUFJ35
http://db.tt/J1MTBmT
http://db.tt/X7KKb3w
http://db.tt/FVoOPiw
http://db.tt/OZZUzlz
http://db.tt/N9tr3zd
http://db.tt/H8LxxES
http://db.tt/rs454ww
http://db.tt/2922s08
http://dl.dropbox.com/u/10275070/fini/10.jpg
http://db.tt/zozlcCk
http://db.tt/ZYDDhFO
http://db.tt/gf55bop
http://db.tt/tA0fb8u
http://db.tt/GhE3vzA
http://db.tt/3Z8Bk4y
http://db.tt/c5J51qo
Final Specs:
CPU:Intel Core i5 750 @ 4.0GHz
Motherboard:MSI P55 GD80
GPU's:ATi HD 4890 XXX Edition (X2)
RAM:4GB Corsair Dominator 1600MHz
PSU:Silverstone Strider Plus 750w
Case:Corsair Obsidian 700D
HDD:Samsung Spinpoint F3 1TB
Fans:Scythe Gentle Typhoon 1450rpm
Watercooling Components:
CPU Block:EK Supreme HF
GPU Blocks:EK FC4890 CF
Pump+top:Laing DDC w/ EK X-top
Rad:Black Ice X-flow 360
Res:EK Multioption 250
Tubing:7/16" Tygon
Fittings:BitsPower 1/2" barbs
Mods:
Custom Motherboard tray cover.
Custom mid-plate cover.
Stealthed CD-Drive.
Powdercoated CD-Drive.
Braided cables.
Scratch made cables.
Windowed side panel.
Painted RAM.
Painted Fans.
Painted rear brackets.
Stealthed CF connector.
http://img543.imageshack.us/img543/2488/img0090t.jpg
Uploaded with ImageShack.us
http://img337.imageshack.us/img337/2292/img0098uq.jpg
http://img52.imageshack.us/img52/8969/img0094qn.jpg
http://img13.imageshack.us/img13/6364/img0101pb.jpg
http://img217.imageshack.us/img217/5050/img0103bt.jpg
http://img607.imageshack.us/img607/7559/img0112y.jpg
specs:
MOBO: GIGABYTE X58A UD7 + EK FULL COVER WATERBLOCK
CPU: INTEL CORE I7 920 @ 4.0GHZ 1.32vcore + EK SUPREME HF
RAM: CORSAIR DOMINATOR 1600MHZ 8-7-8-20
PSU: CORSAIR HX750W
CASE:CORSAIR 800D
GPU: POWERCOLOR RADEON 6970
SOUND CARD: CREATIVE SOUND BLASTER X-FI TITANIUM FATAL1TY
STORAGE (OS) OCZ VERTEX 2 120GB
OTHER STUFF: 2WD CAVIAR BLACK 640GB RAID0
Just finished putting my system in its new house. The case is better than I anticipated. I can't look at this thing with out getting a sh*t eatin' grin on my face. This thing builds cleaner than a virgin on prom night.:rofl:
A whole new system will go in here this spring. Looking at the new 1155 socket and the 570 series video cards.:D
Milky1: do you have some worklog? I'm interested a bit in how you did stealthed dvdrom drive.
Yes I do, not on this forum however, but there is one HERE
Most of these cases are heaps better than mine, but here goes :P
Modded 800D, the bits:
Cutout hdd cage, and fit 240 rad
360 rad in top
mcw655 pump
Swiffy Apogee XT cpu block
mcw60
mcw80
micro res
System:
Giga X58 UD3R mobo
6Gb Gskill Trident 2000mhz
i7 950, 4.2Ghz daily
EVGA GTX 480
Giga GTX 480
HX1000 psu
raid0 74g raptors + 1Tb WD Black
Here she is!
http://i6.photobucket.com/albums/y21...rgoth2/054.jpg
http://i6.photobucket.com/albums/y21...rgoth2/050.jpg
http://i6.photobucket.com/albums/y21...rgoth2/056.jpg
http://img96.imageshack.us/img96/5856/002bwu.jpg
Heres a couple of photos of my 700D
just got it running & still a lot of work to do
won case on ebay for £85 so not bad
had to fit thermochill PA120.3 in roof which was a pain due to the 25mm spacing
Thinking about changing to sandybridge 2500k but not sure it will worth it
To Ketel One
They are 6-32 hex bolt screws. I got them at ACE Hardware for about .20 each. They are cheap and the look great!. I also used nylon washers to make sure the screws did not touch the fins on my radiator.
My 800D best 100 bucks I ever spent :)
http://www.overclock.net/attachments...b-imag0077.jpg
Hey i see a lot of you are use a water cooling solution with this case. For those using a hsf do you find this case has bad air flow? Looking at some comments on corsairs forum i have hear this mentioned a couple of times. If you do think the airflow is bad do you think putting a fan on the side of the case would help a lot?
heres mine. im about to add a second loop for the videocards and im watercooling my soundcard :)
http://lh6.ggpht.com/_CxxgZsM5qaA/TR...2018.02.00.jpg
http://lh5.ggpht.com/_CxxgZsM5qaA/TT...0/P1020826.JPG
http://lh5.ggpht.com/_CxxgZsM5qaA/TT...4/P1020820.JPG
http://lh3.ggpht.com/_CxxgZsM5qaA/TR...2018.06.13.jpg
ELDER: how is the mesh being held up? the PSU bay looks like it has some sort of clip, but what about on the side and back of the 5.25" bays?
Milky1: did you follow a guide on how to ghost your dvd drive or did you just wing it? I'm interested in ghosting mine but need some tips on how to do it
I got the bolts and the washers, but I also got some rubber washers to put between the fans and radiator and the radiator and the top of the case. Did you have any problems putting yours in because I had to make a couple of the mounting holes in my case a little wider on one side to make the holes line up.
I think it turned out good though :)
http://i10.photobucket.com/albums/a1...g/IMG_0092.jpg
KetelOne:
The holes lined up with no issue with my rad. Because I have a triple rad I had to move it around slightly to get each hex screw to line up but they all went in without issue.
Looks great bro!
CK
Sry, have a silly question, but.. am i right ? that the hotswap works only for, like secondary disc's ? not for my main hdd.
Cause i had to mount the main hdd to lower side of the case and connect directly to the motherboard!
Thats a crazy VORTEX going on in there! Isnt that LOUD? I know that when I refill my loop, in the process of bleeding the bubbles, I can hear the bubbles pass through the tubes and its loud. I dont have a single bubble in my reservoir either after the bleeding is over in like 24hrs of running the system, seams like you got a lot of air in your loop.
Just an updated picture of my gaming den.
http://i409.photobucket.com/albums/p...1/IMAG0110.jpg
GT Dominators are used for too long, I returned to the G. Skill Trident.
Once again there is dark ...
Another change, SLI ... oh yes, much better now :yepp:
http://img708.imageshack.us/img708/9252/p1060654q.jpg
http://img197.imageshack.us/img197/3853/p1060489v.jpg
http://img842.imageshack.us/img842/9601/p1060250p.jpg
http://img838.imageshack.us/img838/8231/p1060256z.jpg
http://img842.imageshack.us/img842/8524/p1060318u.jpg
http://img687.imageshack.us/img687/1574/p1060834u.jpg
http://img121.imageshack.us/img121/6082/p1060484g.jpg
http://img72.imageshack.us/img72/22/p1060290o.jpg
http://img38.imageshack.us/img38/3406/p1060874h.jpg
http://img219.imageshack.us/img219/4581/p1060873q.jpg
http://img21.imageshack.us/img21/3025/p1060870c.jpg
http://img23.imageshack.us/img23/7558/p1060871.jpg
Update motherboard CPU and ram and clean up cables etc
great case :up:
I agree, it'll 10 times better after you clean up your cables. Other than that, good job.
