ahh that cards only very slightly if not the same size as 4870 so i expect it do be the same as the 4870x2 atm...
you can see if you get a pic of a 4870 from google, from a similar angle, line them up under each other and you can see =)
no.. no bottleneck hence why the 4890 2gb cards are fine.. honestly you could up the clock 200mhz on the memory and no difference in performance maybe 1/2 % the performance was all in the core clocks etc..
Nah it's fine the vapour card iirc, uses half slot vent, the difference it makes is neglible so its all good :D
