I would always go for Super Talent :up: This is the same heat spreader as Project X 2200 CL8, I wonder if there is any difference under the hood
Their 2GB WX200UB2G7 Project X 2000 7-7-7-21 1.65V looks awesome too me for OC
I was just looking at those Super Talent myself, im debating on trying those out or just going for the new Corsair 2250 cas 8 GTX stuff, as my current 2000 cas 8 Dominator GT's wont do over 1720 ish stable at cas 6 no matter the voltage i throw at them
Dragon
Well the Corsairs are $150 more, not sure there worth it, i would try the Supertalents, good bang for the buck:D
my attempt on crucial value ddr3 1333 cas 9, volt is a 'lil bit high imo but not bad consider d price, ~$99 for a pair... :)
http://i48.tinypic.com/2z4a551.png
1700 done w/ rather high volt... :shakes:
http://i49.tinypic.com/2vwh214.png
Is this the same memory I'm running ah_khoo?
See this post: http://www.xtremesystems.org/forums/...&postcount=349
I'm just curious, because you say your running High Voltage while it looks like its set @ 1.25v, and my subtimings are a little better than yours...
BTW: I've gotten mine stable @ 1600 7-7-7-18-24 @ 1.70v.
I'm probably missing something here as far as kits go, but Crucial always seems to offer some nice bargain ram... :up:
Dave, the 1.28v is the HT and 1.86v is DDR. :p:
I see it now man... Yeah, 1.86v seems pretty high. ;)
I bought mine as a kit, but it looks like the same gear. 1333 CL9 @ 1.5v stock...
Mine is running @ 800 7-7-7-18-24 with 1.70v.
Maybe we can both take a little knowledge away from this. :up:
I may be able to crank the frequency (with volts) and you may be able to tighten sub timings... :yepp:
All in all it's still nice stuff for the price!
sure, but i know very 'lil in ram timing, especially those alphatiming which make me :shrug:...
the thing i noticed bout these sticks is they're quite voltage hunger @ high freq (not so high if compared to performance ram), for a mere 10+Mhz increase, i need to bump vdimm a notch. i will stop @ 1.9v and see how high can it fetch. :)
voltage & mileage wise could be down to how well is d imc of chip i think. d b50 i'm usin now is kinda weak in imc & overclockability, i can't get 3.6GHz prime stable unless i pump > 1.4v. NB Frequency too max out @ 2400MHz w/ 1.3xV... :(
ur runnin on c3 chip which have superior imc, i'm sure u'll do alot better... :up:
yup, gotta agree d item is good for its price... ;)
I think that was like 1.72-1.76 on asus.
I still stand by my CSX Diablo D9GTR @ 6-6-6-18-12-90ns @ 1600mhz :D
http://img.photobucket.com/albums/v372/Reheat/csx.jpg
I bet you have to pump at least 2.2V into them for that, no?
If I recall, they did fine @ 2.1v but I have them @ 2.2v for more overhead under load conditions etc... :yepp:
I bow in the presence of the mighty one for I'm just a measely gamer.... :worship:
At USD$150 a pop, they are hella cheap compared to what I get back home plus CSX dont exist here.... :yepp: :D
cas 5 stuff is $134 for 3x1g. 2 sets bin for best 4, sell off a set. About same price, less volts, less heat, win win.
Kingston is preety widely avalable in singapore isn't it? Not really sure but when in taiwan i saw quite a bit of it.
Out of curisonity where in the heck did you find diablo GTR 2x2g for $150 a pop in USA?
Ahh, this was sometime back though. Yes Kingston is widely available here. I got mine from Tankguys. I had the concierge of my forwarder order it for me as they refused to accept international cards. I was inspired by your gospel that AMD needs a minimum of cas6 @ 1600 to reap the benefits.... :D
heh well cas 6 still better than cas 5, after about 3600/2600 cas 5 scaling dies :( Need more speed at that point, 1600 isn't enough
Yep I just went searching again and tank guys has them listed but no stock for $149. :(
I just want another set to add to my rather large collection, 2x2g gtr is missing.
I'm sure they will have them restocked.... :up:
hey guys are these sticks good.
its the only dominator gt's i can find currently.
http://www.vatanbilgisayar.com/corsa...spx?I_ID=40218
