well i got everything install , but i do have a question everest is showing me these readings , does this look wrong for temps and volt
Field Value
Sensor Properties
Sensor Type ITE IT8720F (ISA E80h)
GPU Sensor Type Diode (ATI-Diode)
Chassis Intrusion Detected Yes
Temperatures
Motherboard 34 °C (93 °F)
CPU 22 °C (72 °F)
CPU #1 / Core #1 21 °C (70 °F)
CPU #1 / Core #2 18 °C (64 °F)
Aux 38 °C (100 °F)
GPU Diode (DispIO) 42 °C (108 °F)
GPU Diode (MemIO) 49 °C (120 °F)
GPU Diode (Shader) 44 °C (111 °F)
Seagate ST3250820AS 37 °C (99 °F)
Seagate ST3320620AS 42 °C (108 °F)
WDC WD3200AAJS-65RYA0 46 °C (115 °F)
Cooling Fans
CPU 2213 RPM
Chassis 2090 RPM
Power Supply 2064 RPM
GPU 3636 RPM
Voltage Values
CPU Core 1.41 V
+2.5 V 3.01 V
+3.3 V 3.26 V
+5 V 4.92 V
+12 V 9.98 V
+5 V Standby 4.95 V
VBAT Battery 3.34 V
PC Probre is showing me these temps and Volts
VCore - 1.41V
+12V - 12.03v
+5V - 4.92V
+3.3V - 3.26V
CPU TEMP - 37C
MB TEMP - 34C
CPU FAN - 2213
CHASSIS FAN - 2089
CHASSIS2 FAN - 2070
