Charles, for the grill, consider that seed of thought firmly planted (and occasionally watered). I pondered on the workflow required and it shouldn't be too difficult (hope I'm not jinxing myself here, cross your fingers). Remove panel, measure, measure, re-measure, cut, file, apply magic anodizing pen i.e. sharpie, reassemble. Should only take a couple hours, which naturally will translate to about 4-6 hours. If by the end of the workday I'm still comfortable with the idea, I'm hitting the dremel after dinner.
Like I said, your creative input is always welcome. :up:
Any other suggestions out there (for the grill or overall)?
The optical drive slot I'm not promising anything more than further consideration. I will likely leave it as-is, it's as what I'd envisioned all along. Colored acrylic cover maybe? I dunno...something to mull over. I'm open to ideas to tart up the top 1/3 of the faceplate a bit. Those three murdermod lines actually look kinda cool even though at first glance they looked like trickling blood or a mini velociraptor attack.
