I just got a P45-T2RS+. Q Connectors are great, I don't need Asus anymore. Does anybody has a template for 45nm quads?? Many thanks in advance.
thatīs crazy board :D
600 x 6
bootable vFSB 1.16V and vNB 1.36V
SPI 1M vFSB 1.23V and vNB 1.37V :up:
e8600 Q824A347
cpu features all disabled
ram 5-5-5-15-55 PL10 , T2 disabled, fine delay 3-3-1, rest on auto
SB/PLL 1.55
clockgen 3.45
gtl 63/63/58
skews 200,100
http://img228.imageshack.us/img228/2...t600au8.th.jpghttp://img228.imageshack.us/images/thpix.gif
Almost forgot to update this thread, there are just too few quads here.
Q9550@473FSB@4 GHz@Jr,
http://www.xtremesystems.org/Forums/...2&postcount=11
the new bios 0901 is out and I wondering if I can flash via winflash like later bios? The instruction on bios page is other way than flashing from winflash.
I have no floppy drive and have to do other way.
Can you guy please advice thank.
http://us.dfi.com.tw/Support/Downloa...FLAG=A&SITE=US
i still prefer to flash bios in DOS... if you don't have a floppy, you could use a USB drive...
http://csd.dficlub.org/forum/showthread.php?t=1136
http://www.student.livjm.ac.uk/cmpsg...rive_guide.htm
On a board with a non-removeable BIOS I think I would follow the instructions given. Unless you have the means to program the BIOS at the hardware level.Quote:
Please restore new BIOS's zip file to floppy disk or USB memory stick and must run "autoexec.bat" in Dos mode.
can i mount Thermalright HR-09U/S on DFI P45 T2RS ?
it says that is compatible with P35 T2RS
Can anyone confirm that the issues regarding the non plus edition are fixed(fsb issues and ati issues)? I have this board coming in next week and I hope all is well with it. Also has anyone tried the 9/30 bios for the non plus?
http://us.dfi.com.tw/Support/Downloa...FLAG=B&SITE=US
Did you hear something (scores, OC and so on) about DFI LP UT P45-t2rs?
Sorry i have to add to this im also looking to get this board and as i cant find the plus board i would have to go with the non plus is it as good as the plus
cheers
Good news: http://scan.co.uk/Product.aspx?WebProductId=884418
Been a long time since I bought from there though :)
are there any deferences between t2rs and t2rs-plus?
If i have the chioce, i will choose the t2rs-plus. All the good results are reached with the plus-edition. In germany some guys have problems with the non-plus board.
They are not 100 % physically the same.
On the other hand I see that DFI has removed bios 901 and also 923 beta for T2RS+ from their website. :D
and I was about to flash to the 0901 bios since it was in the official bios section.
They removed it? I flashed it the day it came out and seems ok for me..
Same here, allthough i'm having a hardtime getting my new E8600 stable with my T2RS Plus at 7.5 x 600
600 lol, my board cant even run 500 with any degree of long-term stability.
Downflashed my P45 T2RS Plus with the 0812 bios and I have the feeling that this bios seems to be more stable for me.
I'm having some issues with overclocking my Q6600 on this board.
I'm a bit of a n00b at o/c, I understand the basics, find your max FSB, find your max Mem, increment V to find stable etc.
Doing this last night I was trying to get find my max FSB, and god be damned, I couldn't get past 370FSB.
I used the document here as a guide. I realise it was for a E8500, but I used all the lowest range of values in this document as a starting point then incremented the different V's up to try and get stable, with the exception of vCore. I used +200mV as a max.
But still couldn't get past 372FSB. Anything up to about 385/390 made Vista restart mid-boot in a continual loop, and 390+ made vista BSOD on booting. 400+ meant clear CMOS.
The weird thing is I can get 370FSB with 1.238V vCore and minimum vNB and rest on defaults.
I came from a GA-P35-DS4, which I got this CPU to 400x8, but not 100% stable and with 1.35V, so I know the chip can get 400FSB.
Can anyone give me some guidance. Would love to see a 3.6Ghz 24/7 o/c :)
Some specs to help:
DFI DK P45 TR2S Plus (need to check BIOS)
Q6600 G0 1.3000VID
2x2GB Team Dark Xtreem 1066 5-5-5-18
Gigabyte 4850 ZL
