To answer your question, I was at 0 since My last Run was last November. Can't wait to bench on my GTX 280 FTW
we just moved to 4th place!
zeneffect - XtremeSystems
347th - 145.3 points
Global Rank: 347th - 145.3 points - (highest rank ever: 347th at 25 Jun 2008 12:00, most hwboints ever: 145.3 points at 25 Jun 2008 12:00)
Benchmark results: 19 (submitted online or scanned and authenticated)
Member status: XtremeSystems member
Date joined: Monday 18 February 2008
YAHOOOOOO!!!!! moving on up..... :up::yepp::p::D
I benched my 8800GT's but didn't feel like mentioning it, a measly 15 points or so as it was effectively a stock clocks run. Waiting on the dewar to arrive, next week I reign down hell upon the 8800GT segment :cool:
After I get my board back from RMA, I can try my best to battle you single card :D
VGPU: Idle-1.34v Load/3D-1.41v at stock cooler, this wasn't to show score, but just stability run to check clocks.
http://i210.photobucket.com/albums/b...0006-14552.jpg
Yeah damn straight, dinos just put up some killer 8800gt runs last week. :up: I only modded one of mine so far because in spite of buying what I thought were identical cards, from the same store, at the same time, my 8800gt's have 2 different pcb's so I need a different trimmer to do the gpu vmod on the second card :shakes:
They both have the samsung ram though so that vmem mod is on my list too. My 790i should be back from rma early next week so I can play too although noone is in any real danger since I only bench air. :D
Just saw Dino's new scores, 5500MHz. That'll be quite interesting to see what I can manage with LN2 with a QX9650. Disable all but 1 core I suspect and maybe I can hit that :D Hopefully some serious GPU clocks will help me.
If this contest is going on, I just added another ~100 points, pushing XS over 10k :D Less than 400 points for 3rd.
Go Gomeler!:up:
I was over looking at HWBot numbers yesterday.
damn I missed some things.
The numbers in some of the apps I can kill with the clovers for maybe the 2 points per and nothing on E5450 harpers so far and I think I can rule there till someone gets out some DI or phase and that isn't common on a $4000.00 parts machine.:up:
im waiting on another e8500 that will hopefully bench @ higher than 5.1ghz... the one im using currently is just not doing it for me. i want to destroy some scores for 2900's (too cheap to upgrade gfx right now, however many points can still be had w/ what im running)
Hrm. Fugger, how much longer will this contest go on? Could use a Vantage key :D
I thought I wouldn't be able to bench again in this competition.
I guess I was wrong!
P45 motherboard arrives this week, so hopefully I will have something to work my scores up :D
LoL... 3d vantage ate my q6600 paired with 9600's for a snack :ROTF: I haven't tried it with any of my other gear yet.
http://service.futuremark.com/compare?3dmv=48354
Ill go with Loonym's results, shows who was busy.
aicjofs OCZ900MXS + Key
loonym OCZ780MXS + Key
mrlobber Key
[XC]gomeler Key
The Nemesis Key
MaxCFM Key
WesM63 Key
ZenEffect: Key
NBF Key
jcool Key
Im working on the 3D team group now.
I will send Key's via PM
Please send me shipping info to send PSU
Grats guys on moving into fourth, this was the first push and I will do better on making these pushes go much smoother.
w00t! KEEP BENCHING!!!!!
EDIT: Posted in other thread.
