Originally Posted by
shawn1998
I'm really glad a few of you have been able to install Vista 64 without an issue, but this doesn't mean that there isn't something wrong with our boards. So, go ahead and come on down from your pedestal.
As far as what board I am currently running, yes it happens to be a Gigabyte. But you might want to learn a little bit about someone and there experience before saying things like that. I have owned and operated almost every motherboard out there and have recently used the DFI P35 and the X38 motherboards. I know how they work and how to set them up. I just sold off the X38 last week, figured I had played with it enough. Also, DFI motherboards can operate at stock settings without tweaking. This is a fact, deal with it. If a simple OS install makes it freeze, at stock settings with kniown good hardware, then there are issues and believe me, they are not ram related either. I installed Vista 64 on the DFi X38 last week with the EXACT same components in my sig, but the X48 will not work? Board problem, not ram. Besides, apparently user cstkl1 didn't bother to pay attention to my posts. Go back and read them, you'll actually learn what I have done to troubleshoot.
Now, to pauldovi, sounds like we are having the EXACT same failure. Interesting. I'll let you know when my replacement board gets here how it works out. I'm willing to bet it will be just fine after that. DFI boards can be a bit finicky, but not like this, this is different.
As a side note, one good thing to report about the DFI X48, the Areca ARC-1210 raid card is recognised at 8X in the 2nd pci-e 16X 2.0 slot. In the DFI X38 it was hit or miss, but not in this board, so that is good news.
