Yeas i think this is the one i have to go with too bad there is no 780i with two PCIE 2x 16 only not 3..
I've been tinkering with my eVGA 780i since last weekend.
Finally, 5 days later I've got an overclock pegged down.
With the E6850, I've managed a 3.825Ghz overclock with a 1700 FSB. The CPU needed a slight Voltage bump but the North Bridge, South Bridge, and every other motherboard voltage has been left at AUTO in the BIOS.
Has someone taken on the chore of developing a 'chart' per-say that shows how much extra voltage they needed to give the different components to achive a given FSB? Like, how much to hit 1750, 1800,1850, etc.etc.etc.
has anyone had problems with their ram on 780i's yet? my 4x1gig OCZ 1066,mhz SLI's wont boot if set properly but my $16 1gig of generic 800mhz clocks mad. i keep getting A0 post error.
do you have the hotfix for vista 64 and 4gb ram?
hmm... well if you manually set the correct timings and voltage then im not sure. wait is it not posting or is it not booting into windows?
most of the time it will not finish POST and hangs. other times it BSOD's before windows loads. this is at stock settings, not OCed at all. with my OCZ's on the board it wont run at all. they are micron D7's. they work fine on my 680i and can OC to 1230mhz fine. i have done memtest on all 4 sticks and nothing is found to be wrong.
i think i have the same ram as you (http://www.ocztechnology.com/product...n_dual_channel) and im having problems with it too but not as serious. for me windows boots fine, but when i enable sli my games keep crashing. and thats only with 4gb - with 2gb everything works great sli and non sli.
yeah my second 780i did that same thing. this is my 4th one now and all have had problems. im tired of this board. i want 790i NOW. they should let me upgrade to the 790i seeing how many problems i've had on the 780i's.
so you mean your games would keep crashing when sli was enabled with 4gb? did you try sli with 2gb?
when is 790i coming out?
no i meant with your 2nd 780i board. you mentioned you had the same problem as me.
For my 4.0 gHz oC on the 9650 I got it stable with these settings...
400fsbx10
Ram linked with 3:2 ratio for 1066 mhz 5-5-5-15 (Ballistix 1066)
voltages Im using,
vcore 1.425
fsb 1.3
spp 1.45
mcp 1.525
ram 2.2v
I can run the vcore at 1.3 for 4.0gHz if all i'm doing is superpi or something, but I've found this is what it needed for an overnight run of prime95 small fft's, and with vdroop the actual voltage is alot lower, this board has lots of drop.
Each CPU is diff, I'm sure there's alot of better 9650's that mine, this is just my case.
yeah i noticed how bad the vdroop is. i set my vcore at 1.3625 and while running prime cpuz/everest report vcore at ~1.27. whats the maximum voltage the 9650 is rated for by intel?
there is a simple and safe vdroop mod on the 1st page you should try.
yes, timings are at 5-5-5-15-2T and voltage is currently at 2.2 but i have tried it at 2.3 and that didnt help so i brough it back down to 2.2. and im not using the EPP/SLI ready function either because i cant - for some reason the mobo doesnt detect it as sli ready so i dont have that option anyway.
is it reversible? i took a look at it but im not sure exactly what to do with those red areas. write over them with a #2 pencil?
Looks like one of your modules lost EPP settings.Run CPU-Z and check SPD tab to see timings for all of your modules.You might find that EPP timings on some of your modules are all messed up.Here is how mine looked when that happened to me.
http://img223.imageshack.us/img223/4672/cpuzoe5.th.jpg
Notice EPP timings on the screen shot on the far right hand side.
If that's the case you can you can use this tool to correct EPP timings http://forums.techpowerup.com/showthread.php?t=20349 .That's what helped me when my memory was not showing as SLI ready.
