but... but... it's so expensive!!! :DQuote:
but... but... it's the maximus!!!
$220 for a mobo is pushing it for me, but i will do it anyway! :p: i got lucky and got a deal on my current board for for $99 :D
good point. :D
If your gonna buy HD3870's I wouldnt bother with Thermalright HR-03's....when you can go and get Thermaltake DuOrb's and get the same effect with half the space taken.
Just got done installing them,
http://i11.photobucket.com/albums/a1...X/IMGP0556.jpg
http://i11.photobucket.com/albums/a1...X/IMGP0559.jpg
Before the card used to idle at 50-55C or so (bout 20-21C ambient) and go all the way up to 85-90C at load with Crysis.
The result?
http://i11.photobucket.com/albums/a1.../Capture-3.jpg
Will be testing load temps later on.
cheers :up:
That looks awesome! though after buying all of this, i will be broke... so i'd be with stock coolers for a while :down:
But i will consider those, thanks!
ChaosMinionX,
Are those coolers TT VGA Cooler?
Just wondering as it doesn't say HD2x00 or HD 3xx0 compatable. If that is the one I think I'm going to put that on my new egg order. Which will be the exact same time more 3870's come in stock. Still waiting to buy 2 more.
^ yup those are it. the mounting holes on the HD38xx are the same as X19xx cards, so any gpu only cooler that fits X19xx cards will fit.
@ Chaos, are the DuOrbs loud? i'll only consider these if their quiet/near silent.
chaos, how do you like the performance of those cards in xfire?
nice...
im just waiting for store thats not overcharging these babies,
my DFI LT x38 should be here next wednesday so i need to order em
Do 3870 in crossfire scale well at lower resolutions?
anyone found the new ati flash tool yet?????? we need to get these cards overclocked with the new bios and see if they can beat the 8800gt.... that would be beautiful... :)
Any of you guys with CF configurations are using Vista64 and have checked Overdrive in both cards is working?
I think Chaos is. Does it work well in vista x64? i would also like to know, since thats what i will be using
Purecain do the cards scale well at lower resolution like 1024 768 or 1280 1024 and what type of fps can you get at those res in crysis with everything set to veryhigh?
i found this site http://www.gpureview.com/show_cards....547&card2=518# it calculated the pixel fill rate after upping the core and mem clocks... very interesting...
hd3870 overclocked to 900mhz core, 2390mhz DDR
Manufacturer: ATi
Series: Radeon HD 3k
GPU: RV670
Release Date: 2007-11-15
Interface: PCI-E 2.0 x16
Core Clock: 900 MHz
Shader Clock: 900 MHz
Memory Clock: 1195 MHz (2390 DDR)
Memory Bandwidth: 76.5 GB/sec
Shader Operations: 288000 Operations/sec
Pixel Fill Rate: 14400 MPixels/sec
Texture Fill Rate: 14400 MTexels/sec :up:
and at stock...
Manufacturer: ATi
GPU: RV670
Core Clock: 775 MHz
Shader Clock: 775 MHz
Memory Clock: 1125 MHz (2250 DDR)
Memory Bandwidth: 72 GB/sec
Shader Operations: 248000 Operations/sec
Pixel Fill Rate: 12400 MPixels/sec
Texture Fill Rate: 12400 MTexels/sec
now whats the pixel fillrate of the the 8800gt ?????
ahh found it, thanks tom....
EVGA 8800GT SSC:
Core 700MHz
Shader Clock 1600
Memory Clock 1000
Memory Bandwidth 64
Shader Ops 179200
Pixel Fill rate 11200
Texture fill rate 39200
looks promosing doesnt it..... ;)
anyone has 3850 256mb crossfire review with GAMES ?
I've found one with ASUS 256mb 3850CF in 3dmark06 scored 18500+ with default setup.
I am thinking about 512mb 3850CF
but I cant find a right MOBO.
can you guys give me a hint ?
i m looking for a 8x + 8x, so will 975x do? I also want to keep the OC ability
gonna need FSB around 450-500
P35 blitz extreme is still too expensive for me =(
plz help me out here :welcome: :welcome:
the P5E X38 would be the way to go, no point buying an old chipset.... the P5E is cheap enough m8....
Nice, I would love to see if Overdrive is also working in 3870+3850 CF + X38 in Vista64.
Chaos some Crysis benches? :)
Purecain what performance are you getting in Crysis with two 3870 and ist playable at veryhigh with no aa at 1280 1024 or 1024 768?
i played the whole game with high-V.high settings at 1680x1050 and had 24-49fps... even @ 24fps(which didnt happen to often) crysis was still sharp so no mouse lag or anything. i'm hoping the new bios gives me another 2-3fps with 900mhz core... ;)
and the overdrive feature works flawlessly overclocking both cards in vista 64bit....
excellent news :-)
just waiting on pay day now
wuts the cheapest price for X38 ?
