@Sitti,
Lock the PCIE Frequency - 100 as well..
@Sitti,
these two settings can greatly affect your stability if not right
Ai Clock Twister - Strong
Ai Clock Skew for Channel A - Auto
Ai Clock Skew for Channel B - Auto
Ai Transaction Booster - Enabled
Boost Level - 2
I increased the CPU PLL voltage from 1.5V to 1.6V! Now it`s working 1600Mhz, 3.6Ghz, 14h. ago!:)
15. h. crashing!:shakes:
& 2 Hours OCCT
http://img339.imageshack.us/img339/6...0occt80xk9.jpg
In my book "daily non 24/7", is stable enough :yawn2:
Something is wrong with this board! One of my friend told me, that the new X38 boards are betters. A tryed the max FSB at 8x! Memorydivider 1:2, the board stopping at 440FSB, memorydivider 5:8!!! going up 475 Mhz FSB!!! Strange!:shakes: With my G0 Q6600 1:2 470Mhz FSB!!!
Hello,
I have a general question. I see that a many people are overclocking their QX9650 to 4GHz or over. I have been thinking about going for 4GHz. I understand that it will require a voltage of at least 1.40 or a little higher. Is that still within the "safer" range of voltage? Someone at the other forum said exceeding 1.40 could damage the CPU.
That is a good overclock mhdabiad
However I've noticed you've got the same errata my QX9650 was RMA'd for (it's actually a documented errata to which has been discussed in the "Core Temp" thread).
Basically 2 of your cores are not reading the core temperatures correctly and this can cause problems (well it did for me) it seems that the 45nm CPU's are plagued with this problem :( .
John
That does not bother me much:) , as long as loaded temps are within norm:cool: .
You have a point if it gives u problems.
Refering to your thread, in my case still better than unknown replacement chip and if it was bad oc'er i'd do it anyway.
This is the least of my worries mind u, after i installed raid (3x500gb). hell broke lose and sudenly my oc is not stable anymore. raised vcore to 1.575 and still not stable in p95 small sft's :shrug:
Wish I had an address to those asus engineer's :explode2:
http://img235.imageshack.us/img235/2465/qx965080mv1.jpg
Hey mhdabiad:
Which cooler are u using for your tests? And also which bios version?
Hi oscar3D,
ApogeeGT/ TC PA120.3/ ambieant 22/ active cooling on NB.
Was stable until I used intel raid, Bios 903.
currently with these settings:
Ai Overclock Tuner: Manual
CPU Ratio Control: 9.5
FSB Strap to North Bridge: 333
FSB Frequency: 464
PCIE Frequency: 110
DRAM Frequency: 1485
DRAM Command Rate: 2T
DRAM Timing Control: Manual (6-6-6-14)
DRAM Static Read Control: Auto
DRAM Static Write Control: Auto
Ai Clock Twister: Auto
Ai Clock Skew for Channel A: Normal
Ai Clock Skew for Channel B: Normal
Ai Transaction Booster: Disabled - Relax Level 1
CPU Voltage: 1.575
CPU PLL Voltage: 1.66
FSB Termination Voltage: 1.5
DRAM Voltage: 1.92
North Bridge Voltage: Auto
South Bridge Voltage: Auto
Clock Over-Charging Voltage: Auto
CPU Voltage Damper: Enabled
CPU Voltage Reference: Auto
North Bridge Voltage Reference: Auto
CPU Spread Spectrum: Disabled
Hi there, i posted this in a dedicated topic but nobody noticed it, so i thought this is the best place for it!
I have a little problem with my wonderful new rig!
Maybe somebody remembers my vga "odissey", asus sent me another one so i fixed this little problem...
Now, i've got some problem with my P5E3 Deluxe + QX9650 + Corsair DDR3 1800!
With the FSB on 450, the system looks pretty stable and it doesn't show any problems, but it often show errors after 1/2 hours of Prime95!
Anybody here with the same rig wants to share his settings with fsb 450 and DDR3 at 1800?
I know it's a little hard for quads ;)
Greetings, Alberto
Hi there,
I am very new with this of overclocking. For now upgrading bit a bit the PC.
As part of my tests, I could update BIOS 0402 with a P4 3Ghz Prescott 630 FSB800 Processor and OCZ DDR3 1600Mhz to 0903... for those that are interested. I don't know if this was going to work... but it do. It is very stable but is getting strange CPU Temp between 40º-75ºC.
Now waiting to getting a new Penryn to do some testing at 1600Mhz FSB/DDR3 to do this synchronous and stable... I hope I could do that with X38 chipset. Any experiences "stables" (included stock speeds) with that config?
Regards.
Hello
I’m completely new to overclocking and have just finished my first build. Upgraded to bios 0903.
Here are some stats running everything at stock:
PCMark05: 6692
3DMark06: 9332
SuperPI (32M): 18m 39sec
Now, here’s what I’ve tried:
FSB: 400
Multiplier: 8.0
Memory Frequency: 1601
Memory timings: 7-7-7-20
I left all the other BIOS settings at default.
Results:
OCCT: Passed
Prime95: Passed 24 hours
Core Temp normal: 30 degrees C
Core Temp highest: 62 degrees C
PCMark05: 8191
3DMark06: 11939
SuperPI (32M): 14m 59sec
So...I was wondering if anyone has any hints or suggestions on where to go from here? I would prefer a higher FSB but my PC won’t POST even at 450FSB. Should I be increasing voltages? Any ideas as to the overclocking potential of my system? Also, I plan to buy a Prelude soundcard - should I set the PCIE frequency to something specific or leave it at Auto? I don’t want my overclocked PC to fry my soundcard...
Thanks for any help.
Brush
PS: System specs in signature.
read this:
http://www.anandtech.com/printarticle.aspx?i=3156
Kappa
Nice find Kappa
let me add a recent review:
http://hardwarelogic.com/news/132/AR...008-01-28.html
My own opinion of this mb so far:
a,more stable than maximus se
b,far less vdroop than p5e
still needs another bios update ......
Fair enough, my load temps were way off to though and got stability problems when I maxed 4 cores. (basically system would hardlock but before it would hardlock core3 would throttle!)
My replacement CPU will be with me tomorrow (RMA has taken 20 days due to a shortage of QX9650 stocks in the UK). BTW what pack date is your CPU?
Once again impressive overclock, but I would be wary of the voltage as 45nm is more sensitive to volts than 65nm Conroe. I have heard some people say do not go over 1.5V and others say 1.45v yet you also have others say upto 1.6V is fine. I guess it all depends on the cooling and how long you want to keep it.
John
New bios 1001 out there..lets see..
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...5/P5E3_DELUXE/
First thoughts...
..better (or more correct..) temps...lower voltages..with the oc profiles saved from previous bios doesnt boot , needs step by step again setting..
still testing...
like always..:p:
Anyone tested bios 1001 yet?
ftp://ftp.asus.com.tw/pub/ASUS/mb/so.../P5E3D1001.zip
I am having a go at it now :D
My friend you dont read posts before yours ..:welcome:
