New beta bios, F5i....also there is anew version of CPU-Z out :)
I´m give up on my DQ6 now, cant get it over 400FSB, i have just ordered the Asus p5e3 deluxe, hope it will go better.
walste> Go back to the F3 bios! Mine has been running at this configuration since I set it up. This is my 24/7 set up, which runs stable as can be!
http://i38.photobucket.com/albums/e1...ntitled-14.jpg
Guys, my DQ6T did 535 FSB out of the box, with no voltage mods. I dont understand why you are having so many problems walste. I am on the F4h bios.
I have the F3h bios right now, but still no go over 400
But on gigas site there are only F3h bios at the latest, where do i get the F4
F5i,quadcore 460FSB stable have no problem
leave all mobo voltage to normal.
http://pic.xfastest.com/hicookie/Gig...32m_13m53s.gif
Then there must be something wrong on my board, cus there is no way at all i can get it to boot up over 400
It could be your CPU, i've had three boards and my own E6600 will NOT go past 450FSB, no matter what voltage mods i make. Some chips are FSB limited.
Some can go past 500 and others can't.
New Bios (f5i):
http://rs44.rapidshare.com/files/64609953/X38DQ6.F5I
Very strange, all of a sudden they removed all of the support and product page of the DDR3 variant X38T-DQ6
Any word on the f5i bios fellas? I will wait for results. Everytime i flash bios i need to reinstall ati drivers;)
There seems to be plenty of people on either side of the fence with this board.
My experience with the GAX38DQ6 has been really good, the board has been stable from day 1 and the temps have been low on the chipset.
Currently running my E6600 B2 @ 450x8 24/7, managed to get to 470 fsb, but no higher than that, but it's the same as with my previous 2 boards I've run this CPU in, it always stops at that fsb, so CPUs are definately a limiting factor, not all will get to 500+ no matter what board you stick it in.
I've got 2 E6600's and neither have got to 500 fsb although the 2nd one I'm not using does get slightly higher than this one, both using PC8500 Dominator memory.
Scored 12950 3DMark06 tonight and there's a few more points to go when I carry on tweaking tomorrow, that with my Dell OEM 8800GTX which cost me £280 + £56 for EK FC8800 Acetal block, clocked to 660/2040.
Tried F4 for a while, but for me it didn't give or take much execpt that the boot time increased by quite a bit, now back on F3 BIOS.
I have installed all the drivers off the site for this mobo.
But in device manager I'm still getting SM bus controller question mark.
Cant find this driver....
Anyone got a link?
Also I can prime my Q6600 @ 3.8ghz but when I try and monitor temps the PC just reboots.
Is this something to do with a driver issue.
Cpu-z is out aswell not displaying correctly. 1.41
Using F5h bios.
I have 4 gig of ram 4 banks of ballistix.
Try this:
http://downloadmirror.intel.com/1088...6_PV_Intel.exe
Works fine for me:
CPU-Z 1.41.1 is also available, it might read things better.
I tend to agree, i've had a P965, P35 and now X38...using all bios that come out...my E6600 will not go past 450FSB, it's stable upto 445FSB...after that it gets dodgy.
I'm happy with the chip 3.4GHz at 1.4V is fine with me....i'm waiting for the new 45nm chips before upgrading the CPU. As for boot time with the X38, there is a definate lag, several seconds on pushing the power button, very weird....it's like it waits to POST,
New Realtek 889A codec drivers, 1.80:
http://www.realtek.com.tw/downloads/...&GetDown=false
New Realtek 8111B LAN drivers, dated October 22nd:
