Originally Posted by syne_24
Well I managed to fit it however I had to add a small stripe of metal with 2 holes on it with one hole screwed on the block and the other used by the screw on the motherboard to push it down. It fitted perfectly this way although I had to take out my Dremel and work on this tiny piece of metal.
It kinda works like the one in the picture where one of the holes on the block is wide.
