I knew it :D
I knew it :D
hehe stunned_guy doesn't like pain :D
when the cpu is here, i'll steal the butter from his toast :p:
Try to get the WR back :) i´m optimistic in that.
hehe... i don't sleep till i get the WR back! ;)
Here is some vcore experimantation:
http://img237.imageshack.us/img237/9...32wzdq9.th.jpg
This cpu isnt hot i wonder why i have such good temps under single stage with that voltage.
omfg, 2.0V :eek:
are you serious? :p:
the max. i gave to my 3700+ was 1.85V, but only because of the coldbug under single stage. :D
btw. have you already tested the 4000+ to the max?
@ Turrican
Cold Bug and max voltage are different things...try to get more the cpu will love it. I didn´t saw a athlon 64 blown because of high voltage.... and of course you also have a single stage so its no problem to try max vcore. Most of that cpu will not boot with higher than 1,904 voltage.
The max prime stabil is 3300 mhz @ 1,408 v...that cpu has a great wall after 1,408 v i cant get more voltage prime stabil....i tried up to 1,7 v to get prime stabil but nothing changed. the same thing under air, 3000 mhz with 1,408 v and no more vcore won´t be stabil :(
Thats so sad :(
Not blown, but broken. I broke my 3000+ venice when I gave it a couple of hours +1.95v under dice. Be very carefull with that kind of voltage :)Quote:
Originally Posted by stunned_guy
That voltages arent for long time only for validation and so on. ;)
My max voltage for prime was 1,888 v @ air for 2 h with 75 °C with an 3500+ Winchester....that was an amazing CPU. That cpu was my first 2 v result of 2,016 v now with the 0546 FPMW 3700+ i could top it :D
hehe stunned_guy you are realy insane :D
New vcore result with an 4000+ Clawhammer with 1.55 x 136 %:
http://img117.imageshack.us/img117/9...64wzyj1.th.jpg
New AMD Athlon64 prime vcore world record:
http://img406.imageshack.us/img406/6...16wzuy3.th.jpg
while 2.064 v were running the pc shut down after 4 minutes....so i had to get down with the vcore...
burn, baby burn :flame:
congratz, nice one :toast:
i'm really stunned now. :D
hehe owned but:
my oc: 2.2ghz @ 3.53ghz = +60%
your oc: 2.8ghz @ 3.7ghz = +32%
:D
Plus the fact that he has unlocked MP which makes it easy to cope with coldbug etc. without running high htt :pQuote:
Originally Posted by gianni-gt
but 3.7Ghz Primestable is awesome :slobber:
congrats Destroyer :toast:
EDIT: and i've also seen the 4Ghz+ Validation in an other forum ;)
really astonishing result :slobber: :toast:
Thats crazy.... !!!!! :D
Some great overclocking there guys.
Congrats to you all. :)
hehe, my 4000+ does 3GHz on air at 1.55V
Make your sig smaller, Ku-sama......
Thx guys....we are all crazy :D
NEW 3700+ San Diego E6 / Toledo World Record: 3654 MHz almost 150 MHz more than my older WR :D
thread reactivation :D why? check this:
i've tested my power-sandiego under my new chiller (built by moc):
http://octs.ripping.org/3700_wr/supe...ller_setup.jpg
the white "snake" is for the ram-cooling :D +12°C air temp...
here are some test:
http://octs.ripping.org/3700_wr/supe...552_23.141.jpg
http://octs.ripping.org/3700_wr/supe...604_22.844.jpg
http://octs.ripping.org/3700_wr/supe...621_22.734.jpg
http://octs.ripping.org/3700_wr/supe...654_22.562.jpg
http://octs.ripping.org/3700_wr/supe...663_22.516.jpg
and here the new wr (old: 22.750sec).... after 3663mhz it was nearly impossible to make a screenshot, thanks coldbug. i've made a photo this f.ucking a64tweaker window :D but the time and the validation-code are visible! strike! :)
http://octs.ripping.org/3700_wr/supe...671_22.469.jpg
tomorrow i'll bring the 32M wr back to switzerland... the russians are atm 2sec faster...
