1.875 ? you are sure? the board is max 1.600vQuote:
my bad - 1.375...I beleive...what ever one step down from 1.4 is...maybe it was 1.385...
1.375 for 3.6ghz is a pretty good chip!
3.0 not 3.6. I could probably go a little higher but Im satisfied at 3.0.
As for the BIOS hang, i was able to talk to tech support and they need me to look at the bottom right corner of the screen to see if any error codes are reported there. If anyone sees this happen remember to check that so they can help troubleshoot it with you.
I get little 2-letter codes that flash at the bottom left corner of the screen everytime I boot up. Is that what you're talking about?
yeah, apparently it functions as bios error codes as well.
Yeah i get those as well but i think mine are on the bottom right side. No fan control in the bios is also a nitpick of mine but at least my idcc works so i can do it there, although that has to be done after every reboot. I'm going to do some final stress testing tonight before i go to bed to see if 3.2ghz is stable enough to keep. It sure runs like a bat out of hell though :)
Can anyone shed some light on why I would get a beeping sound from the board while playing a game? The beep comes intermittent, It does not happen in windows.
From the Product Spec:Quote:
Originally Posted by palese
Memory Error - Three Long Beeps, 1280 Hz
Thermal Warning - Four alternating beeps high/low, high tone=2kHz, low tone=1.6kHz.
Not sure if these apply after post..
IDU/IDCC running ?
It could be a monitoring alarm from IDU or IDCC
Thanks you guys, I'm going to turn off all alarms and test it:) the ram is extremely cooled so that should be OK.
My ram requires 2.4V now on the 680i bios the memory volt selection showed 2.1, 2.2, 2.3, 2.4 and so on, now on the bios for this board it shows 2.40V is this the same as 2.4V
Sorry i'm still learning:confused:
Originally Posted by shogo_ca
I can get TAT and coretemp to work but its a no go for IDCC or IDU:(
right now i'm running my first test of orthos blend test on this board. my proc can do 3.2ghz 24hrs stable @ stock voltage, 1.3vfsb and 1.65vmch with asus p5w DH dlx.
btw, my IDCC cant load .. :(
I can only get IDCC to load if I don't start coretemp, cpuz, tat, etc. If any of these have run even once, IDCC will fail to load. If I start one of these while IDCC is running, IDCC will freeze. So basically, I use IDCC right after a boot to slow the fans down, then stop it and use the other guys to continue testing.Quote:
Originally Posted by malachi1313
Thats weird, i use all of those myself and at times all at the same time with no problems at all. I'm at 3.2ghz at 1.375v and I ran orthos for 5 hours tonight stable before i stopped it to play some TDU. My idle temps have also dropped 3 degrees since last week so it looks like the as5 is finally curing. Im idle now at 38. Still in the low 60's during an orthos load, but in games its low to mid 50's. I could probably push on to 3.4 or 3.6 but whats the point as all my games run smokin' as it is.Quote:
Originally Posted by gtj
Has anyone ran a Xeon 3060 on this board yet, I looked at the Intel cpu compatable list and no xeon's listed:eek:
The Xeon works quite fine. :p:
Currently running @ 3.2 GHZ still on default volts. I will push for more once I have some spare time......:D
Thanks Only:) Well my beep problem turned out to be my PSU :eek: I guess its not compatible with this board, the PSU has beep codes and I forgot about them, the code said I was not running enough devices for it :eek: It said it fell under a certain amp requirement :eek:
Any ideas for a good PSU replacement?
I love mine....:)
The only thing that has me worried about with this board is the limited 1.6vcore, yet on the other side they have 2.8vdimm ?
Sounds rather out of balance don't you all think ?
I got DDR2 1000 @ 3.6GHz 4-4-4-4 going on this board and it's dead even with DDR2 800 @ 3-3-3-4 in performance. At least as far as Pi1m goes. I'm on the default strap.
1000 @ 4-4-4-4
http://img146.imageshack.us/img146/8...bx2cag7.th.jpg
800 @ 3-3-3-4
http://img205.imageshack.us/img205/6...m36gpb8.th.jpg
why with this board my load coretemp is 75c while last time with my p5w dh it's only mid 50's..
**edited**
i reinstalled my waterblock and reapply artic silver 5 and yehaa, my temp back to normal.. now full load during orthos is 52c :D
anyone spotted a vcore measuring point ?
That's the thing, your running crossfire , on my 680i I ran 8800GTX SLI as well as every thing else but now i'm just running one 8800GTX , I use on board sound and one hard drive, I did not know this about high powered PSU's, that they require a minimum about of output :eek:Quote:
Originally Posted by theonlybabyface
I had to install the other 8800GTX just to balance it out.
