Originally Posted by ErikaeanLogic
sorry it's taken me so long to get back to you, shimm, my isp was schizo for the last day or so...:(
basically, these are my settings:
fsb: 411
multi: 9x
bootstrap: 1066
cpu/ddr: 1:1
vcore: 1.4125
vdimm: 2.0
vmch: 1.8
ram timings: 4-4-4
trfc: 28
Did I miss anything in particular you're looking for? Btw, I'm using the B03 bios, too.
I remounted my TTBT last night which dropped my idle temps 2-3C but I still cap out at 81C under Orthos load...no matter what the voltage!:eek: I don't understand why that is.:confused:
My buddy has the same rig as me (3060, AW9D-Max, 2GB Ballistix, TTBT) and can run Orthos on Blend at 423! I'm using the mcx159-cu and he's using the stock chipset cooling, although we've both removed the stocking cooling/heatsinks and applied AS5. He runs at 1.55Vcore and at much cooler temps than mine (~75C under load) even though we have the same cpu cooler. He is using the new TTBT VX model whereas I have the original TTBT, the only difference seems to be that the VX mount is much much easier to affix to the motherboard. I am completely perplexed as to how this could be except to surmise that his IHS is flatter than mine. I'm considering getting either the newer VX or a Tuniq, but as we are near the weekend I couldn't reasonably expect delivery before middle of next week. Also, can I truly rationalize spending ~$70 for 100-200MHz? I know this is XS but that seems like poor economics to me.;) I'd rather wait to see what the rd600 will bring to the table and take a slight hit on the resale of this AW9D.
At any rate, I seem to be walled with blend at 411fsb although I did manage 5+ hours of SmallFFT's at 423fsb. Between the cpu/mobo upgrade (opty165@2.7 vs c2d@3.7) and the video upgrade (1800xt vs 8800gts) I'm loving bf2142 at 1920x1200 with all the bells and whistles cranked up. :)
hth
