I posted this answer elsewhere in the forums
Originally Posted by Revv23
anyone know the deal with the non max?
From what I've read & seen, they both share the same bios. The non max has 4 SATA's vs the Max's 7(plus one external connector) & single lan vs. the Max's dual Gigabit Lan. The most significant difference will be the max motherboard is
enhanced with traditional heavy duty armor plated Solid-State capacitors
The non max has
solid state capacitors in all the essential places
Also the cooling is different. Only the northbrige is connected to the heatpipe. This makes me curious though because if a fan is added to your northbridge then it will be cooled separately from the southbridge and they will not exchange heat across the same pipe. I feel this could improve clocking on this board since they are not exchanging heat across the same pipe, but one would have to think the Max board is designed to overclock better considering the capacitors and all.
http://www.abit-usa.com/images/produ...gle_500_lg.jpghttp://www.abit-usa.com/images/produ...gle_500_lg.jpg
