Not sure if this will hit the market.
Its DDR2 with PCIE
Its DDR2 with PCIE
Holy :banana::banana::banana::banana: ! Now that is a screenshot I can appreciate...considering you guys have benches around 100% overclock to back it up.. :toast: ...amazing stuff from japan everyday.Quote:
Originally Posted by PRTeamJapan
Is this the same P-M or different ones? Some mighty good results.
By duck
His improved modPI 1M 18.562s
LN2 Cooling
M/B:ASUS P4C800E-D + CT-479 / 55MG / BIOS:P4CED23.ROM
M/B Bed:V-TEC ARC Bed
CPU:Pentium M 780
Memory:M.tec PC2700 256MB×2
VGA:GeForce2 MX400 AGP 32MB
HDD:IBM IC35L060AVV207
PowerSuplly:OCZ PowerStream 520W
Vcore:1.86V(Actual)/ Vddr:3.65V(Actual)/ Vio:3.74V(Actual)
Vagp : 1.95V
OS:Windows Server 2003
400MHz CL2.0-2-2-5-4-E-A-A Turbo (1:1 200MHz)、
http://premium1.uploadit.org/fredyam...2s-by-duck.gif
So running 2x512MB instead of 2x256MB is about 0,1s faster in SuperPI when using a Dothan?
When I compare TAM and duck their results (both at exactly the same clocks) TAM is 0,124s faster. And the only real difference in their setups is the mem.
Or do the memtimings make the difference?
TAM runs CL2.0-2-2-5-4-A-A-A and duck CL2.0-2-2-5-4-E-A-A
Both are awesome scores though :slobber:
when running 2 x 256mB set to "Enable" and when running 2 x 512mB set to "Auto", that's the difference between TAM and DUCK timings.Quote:
Originally Posted by SynGroW
C
Those 780 Dothans sure love voltage :D
New WR(0.001s improved) by duck
M/B : ASUS P4C800E-D + CT-479 / 55MG / BIOS : P4CED23.ROM
M/B Bed : V-TEC ARC Bed
CPU : Pentium M 780
Memory : SanMax PC3200 512MB x2
VGA : GeForce2 MX400 AGP 32MB
HDD : IBM IC35L060AVV207
PowerSuplly : OCZ PowerStream 520W
Vcore : 1.865V(Actual)/ Vddr : 3.40V(Actual)/ Vio : 3.66V(Actual)
Vagp : 1.95V
OS : Windows Server 2003
1:1 200 400MHz CL2.0-2-2-5-4-A-A-A Turbo
http://ydsimo.hp.infoseek.co.jp/cgi-.../file/0729.gif
http://membres.lycos.fr/cpulloverclo...que/18.437.gifQuote:
Originally Posted by Enz0
Wow, better each time. Will 4.2 give us under 18.4? I would assume so. Also, would running a 16x multiplier and 261 give them a better time?
of course it should give some boost, but for some unknown reason they can't run those 780's @ that high speeds with higher fsb's than 240~250mhz
I never knew that. I thought that they use to run the 730's @ higher fsb's. Can dothan run half dividers?Quote:
Originally Posted by Sesto Sento
yes, same as pressie or a northy
No 1/2 multipliers for Dothans :(
By 元leader
With his boxed M780
Unpatched English SuperPI: 18s
Clock:4087.3MHz(240.4MHz x 17)
CPU:Pentium M 780 7514B348
M/B:ASUS P4C800-ED 55MG + CT-479
Cooling:Self-made Cu Pot/ LN2
Chipset Cooling:Stock sink + Self-made Cu Pot/ LN2
Memory:Sanmax BH-5 339WF 512MB x2 / DDR400 / CL2.0-2-2-5-4-A-A-A
Vcore:1.890V / Vddr:3.55 / Vio:3.65V
VGA:GeForceFX5200 AGP
HDD:HITACHI HDS722580VLAT20
Power Supply: OCZ PowerStream 520W
http://mtleader.hp.infoseek.co.jp/m780_18s.jpg
WOAH...nice OC man.....wow thats :banana::banana::banana::banana:ing great
Hmm interesting- looks like he has managed to crack the low FSB riddle with 400mhz CPU's
Anychance of any Volt mods to the CT479 , or i wounder if the VIO is the key.
it's a 533mhz cpu.....but cpuz shows it as a 735....same happened with 780ES....
The 18 seconds keep falling.. great work.
:toast:
