Since i;ve used the MSi .. and i know the kinda bugs its likely to put out ... BUT once this bugger gets up and running ... its a sweet board
U cant go wrong with this board + a 3000 NC Core :) ... My Advice.
For a motherboard I would go with a Abit KV8 Pro, make sure its revision 1.1 cause they have working locks. It a great board for overclocking with stock air you with safe voltage probaubly bring it to 2.4ghz. I have a 3000+ OC to 2.68Ghz and went from 23fps to 30fps in the game I play.
thanks for the advice...I checked out the Abit site they have a Abit Kv8 pro and Abit Kv8 pro 3rd Eye...I don't see much differents between the two boards exept the 3rd eye is 10 bucks more (canadian)...since you said I should get the the 1.1 version could the 3rd eye = 1.1 ver...or I should just go with the Abit Kv8 pro and make the guy at the store open the box so I can find out the ver...thanks =].Quote:
Originally Posted by =[PULSAR]=
and to the MSI K8N Neo Platinum suggestion...this board is 50 bucks(canadian) more then the Abit Kv8 pro...is it worth paying that much for nf3 250 chipset over the K8T800 pro chipset???
I have seen a couple reviews with the 3rd Eye and the only difference is you get a couple more points benchmarks, yes they have AGP/PCI locks which would constitute them at being revision 1.1. If your going for records go with the 3rd Eye but if your just benchmarking for curiousity then just go with the regualr KV8 Pro, both boards overclock the same from what I read.
last thing I wanted to ask you about the K8V pro...is there any bios problems...and what version of bios should I have on it...also is there another version after rev 1.1?
cause I think I'm goin with the + 3000 nc cg core and the Abit K8V pro.
I have no bios problems with my rev. 1.1 KV8 Pro, other than bad temp readings. It shipped with the 1.5 bios and I'm still using it. Rev. 1.1 is still the latest. I love this board.
I'm using BIOS v1.6, always have to try the latest. KNW if you can and you havent already AMD is suppose to be having price drops the Oct. 15th so you may save a little money if you wish.
Just to post and let everyone know AMD released a DTR version of the 3700+. Ahhh the advantages of direct die cooling.
^NICE!!Quote:
I was just about to go pick up my new AMD64 setup...but now I might have to wait till the price drops the only down side is...I'm gonna be stuck with a p II 233mhz...but I'll end up saving $20us...could start saving up on a better coolin solution =]...
I also read that they might be coming out with a amd64 3000+ 939 512k (1.8ghz) at the same price as the 3000+ 754...I hope it's soon cuase dual channel would be nice =]...and of course in that case I'm goin with the AV8 =P.
AMD64 3000+ 939 is out Oct. 8th, here is link to buy :D
http://www.monarchcomputer.com/Merch...ct_Code=120421
3700+ DTR Review
MSI K8N Neo2 v1.36b
A64 3500+@2740MHz (11x249)
Corsair 3200XLPRO 2.5-3-3-8 1T 1:1
ya that's sweet but I have to wait for it to come in canada tho =[.
Just an update look at what I found finally selling
http://www.newegg.com/app/viewproduc...103-490&DEPA=0
Hopefull my new job will permit me to buy this and some better cooling :D
Wow, that is cheaper than a retail 3700+ and has a mobile core. It should clock very nicely.
This is my OC
y have athlon64 Newcastle 2800+
cooling by aquarius2 Tt
i can get 2430 MHZ really Got 600 Mhz Overclock =)
nice!
welcome to XtremeSystems :toast:
tanks a lot saaya
guys how much secs at super_pi i can get whith an 3000+ 512k L2 @2700mhz?whith bh-5 2-2-2-5
33-34 seconds if memory is 1:1
Originally Posted by flytek
but whith A64 is better 5:4 2-2-2-5 or 1:1 2.5-3-3-7 or 3-4-4-4-5(TCCD :D)
i'm not sure. i would say 5:4 might win. i never bother unless it's 1:1. give your ram some extra vdimm :D
i have bh-5 i don't know where i can go :DQuote:
what board. find the vdimm mod and give them like 3.3vdimm and active cooling to start
i said on dfi :D
now i have a strange P4C800....max fsb in 5:4 290 max fsb whith every ram in 1:1 258! i used TCCD that do on chaintec of my friend 295 on my not over 258!....boh....
a little air-cooled 2800+ (AX) action, 0430....
1.66v
8 x 311 = 2489, 1:1....
PQI Turbo PC3200 (tccd)
http://img55.exs.cx/img55/473/cpuc2.jpg
I was able to use clock gen to set the cpu to that speed, then when I tried dropping the speed back down it crashed when I pushed set. I was never able to take it that high agian, it would always instantly crash if I tried setting it that high. The CPU is a 4/20 3700+. It is doing 2.8GHz completly stable though.
Nice craig, what kind of cooling?
General question for all: Whats the highest vcore an AMD can take without frying it? Just wondering I'm modifying my BIOS.
Here's a totally unstable max screenie from my week 33 FX53 + R507 prom cooling
http://home.exetel.com.au/codered/fx53/cpuz3256.jpg
Its a good chip ... ehh. This chip will do most benchies at 3127 MHz. See my sig for superpi, pifast and 3dmark01.
A R404a system. I always give my A64s 1.7V as if it was the "stock" voltage.Quote:
True :DQuote:
1:1 real gives a lot performance even with CL3 3-4-4-8 1T like mine
http://www.thelab.gr/attachment.php?s=&postid=110436
Also MEM performance / Bandwidth is Huge when running CMD 1T @ 295 1:1 :D
http://www.thelab.gr/attachment.php?s=&postid=110345
So as I'm wating for the +3000 s939 to be in stock at the local store...I was wondering what mobo I should go with, I was looking to pick up the AV8 S939 K8T800PRO...but if you have any better suggestions please let me knw.
thx.
My CPU: 2800+ CBASC 0413MPM - this is a good week (I tested few and all worked at 2450-2500MHz at 1.5V).
WC-cooled...
2550MHz 1.5V - full stable (Prime95, Superpi, bencharks etc.) 24/7
2700MHz 1.5Vx110% superpi 16M passes at 13'14" - ftp://83.16.182.254/Superpi_16M_13_14.jpg
2727MHz 1.5Vx110% superpi 1M at 32" ftp://83.16.182.254/superpi32s.jpg (I don't like that not exact measure time).
Originally Posted by rapra
Great CPU :D
What was water temp ending Super Pi 16M ?
I don't know :) - but rather low - there is outumn and at the mornings is good temperature to overclocking. maybe 15 centigrades...
15 DEGREE CELSIUS in da hause ??
Don't chill the room-mate :slapass:
here's where I'm currently at:
http://www.xtremesystems.org/forums/...id=18058&stc=1
Hi there I have overclocked my 3400+ NC CPU til 2700MHz..
I wonder how much Vcore it can handle safe with watercooling??
Its not very stable tought but here is the picture :)
http://members.home.nl/ethanol/oc.JPG
welcome Speedy-J
you could give it a little more voltage on water but not much. it will just overheat and crash if you give it too much.
- DFI nF3
- A64 3200+ CBAEC 0428RPMW@1.65Vcore
Water temp @ 25ºC on full load, shes stable for me
http://koti.mbnet.fi/dani69/DFI%20nF...%202651MHz.gif
- DFI nF3
- A64 3200+ CBAEC 0428RPMW@1.72Vcore
Water temp @ 27ºC on full load, shes stable for me
http://koti.mbnet.fi/dani69/DFI%20nF...3MHz%2010h.gif
Ok I have seen a few people...two three in fact that have the same stepping as me.
ADA3200AEP5AP
CAAAC 0345RPMW
9777555K30002
For those of you that do have this what are you getting out of them and at higher clocks do you get memory errors? I need help with this bad.
MSI K8N NEO2
90nm 3200+
GS TCCD
AIR COOLER:HYPER 6
http://my.so-net.net.tw/xu1060/G20.JPG
http://my.so-net.net.tw/xu1060/G16.JPG
@ peter lu
nice overclock m8...:) ime running a 3000+ 90nm on a asus a8v delux rev 2...
this chip need more juice than yours to attain the same speeds...
when i get home from work later ill take some screenshotz...
ime running 290htt @ 1.7v ddr @ 5/4
unfortunatly this ram A-data 4000 dosnet seem to run the 1/1 multy for :banana::banana::banana::banana:... gets buggy at anything over 240htt cas 3-4-4-8-10
where as in the Ai7 it wsas running 280fsb 1/1 2.5-4-4-7... looks like i need some new ram for this setup...
holy crap. 2.8ghz at 1.6v with air is awesome. I am still working out my new winny but the election keeps distracting me;) I am at 260x10 at 1.6v so far.
:toast: Here's to hoping I can make it close to your clock!
Bad mobo :( (MSI K8N Neo FSR)
waiting for RMA to EPoX 8KDA3J
only 2.48 on air (BOX al cooler)
http://www.topmods.net/tin/2488.gif
My Koolance needed to be modded to fit on A64. Damn.
Here's my air cooled FX-55
http://www.aocb77.dsl.pipex.com/3000.jpg
As you can tell from the lack of benches not that stable, will do pifast at 2930Mhz or so though.
Regards
Andy
2800+ NV CG, K8NS, TCCD
9 x 262 24/7 Prime Stable = 2365mHz.....
Venus 12 on LOW speed setting.....
Good enuff' for my multimedia PC
in sig....sata drives are limiting me :(
3200+ winchester, msi
260x10 = 2,6 ghz @ 1,55v rockstable
@ silent watercooling
Heya - I'm new :D
just bought new system (CPU @ MOBO) and wanted to see how far i'll go with Original AMD's cooling @ Adata's 256MB PC3200
(I'm pretty noobish so dont lough at me pls :D )
http://www.hwzone.co.il/ocdb/users_p..._CPU240FSB.JPG
http://www.hwzone.co.il/ocdb/users_p...ndra240FSB.JPG
3dMark 2001SE Rsaults at my signature (9800SE @ Pro no OC)
Hi all,
I am new too.
Got me a Winchester 3500+, check it out:
Click
Are there any winchester's with 1MB of cache?
welcome Yot™ and Takemenow.
Takemenow - what cooling and stepping if you've got it. thanks
Dangerden RBX cooler, Heatercore (dangerdan) and a Dangerden ATI block, eiheim 1048 waterpump.Quote:
Core: 0437 VPAW. batchnumer 128.
All this on a MSI K8Neo2, OCZ Rev.2 Platinum 1024 dc kit, that ram is pretty damn good :banana:
nopeQuote:
I've got a 3500+ (DH7-CG 130 nm newcastle) with 1 gb of corsair pc4000 xms v3.3 and an MSI K8N neo 2. Max stable is about 2.53ghz got to 2.6 at 1.7v but I don't really know if it's really stable.
Is 1.7v even safe (bios 1.55v +10%). I need 1.65v or a bit less to get is stable to 2.5ghz (10*250). The mem goes to 260 at least but doesn't do 1T at this speed.
Can anyone tell me if 1.7v is safe enough to run at costantly. Load temps are about 50C-53C (according to corecenter, Pc wizard 2004 and MBM tell me 48-50C. Idle is 37C at 1.65v and 2.5ghz. I'm using bios 1.3 now caus I don't want to do a manual flash. With my radeon 9800pro 128 mb at 440/365 mem at 3-4-4-10-1T and 250*10=2.5ghz i get 22372 3D01 marks. Sandra scores are mem int/buff'd (6824/6767) CPU arithmetic Dryst/whetst (11514:3955/5157)
Spec's - Radeon 9800 pro, Dfi UT 250Gb board, AMD 64 300+, 512MB Corsair XMS Pc3200 @ 2-2-2-5
http://img53.exs.cx/img53/5606/Snap46.jpg
3400+ at 2900 on a dfi ut 250
i don't think i've hit the max for this chip yet
edit: this is untweaked. i know my superpi time is low.
http://www.johnshim.com/a64/3400at2900.jpg
Sorry to say but 34 sec is very bad for 2,9GHz.
Here's 33 sec at onl 2,55GHz:
http://www.xtremesystems.org/forums/...id=19612&stc=1
yeah sorry... i should edit and say it's not tweaked at all...
i just popped it in... and pumped the voltage up to 1.65 and just ran it...
i got 33 seconds with my 3200+ @ 2.6 so i know that this is low.
http://www.johnshim.com/a64/superpi2900.jpg
Here is my current records on SP1M and 8M on WinXP Pro 32bit:
DFI LP 250GB, 3200+ 130nm (CBAEC 0428RPMW)
http://koti.mbnet.fi/dani69/DFI%20nF...XP%2032bit.gif
Here is my latest overclock ! I running the memory a bit slow but the Cpu is at a nice clock with low temps. 36 seconds on a 3000+ is good right? btw this is aircooled on a Zalman Heatsink. any suggestions?
http://img104.exs.cx/img104/165/Overclock.jpg
Image Link dead.
Originally Posted by Jew-Bagel
i got 34s in 1:1 with bh-5....give them more volts :D
Link fixed, btw what is this Bh-5 i hear so much about i have 512MB Corsair XMS pc3200 @ 2-2-2-5 should i think about getting something else?
rev?
Here is mine,i will be getting my watercooling monday and will go for more.I love the MSI board,i read about how much trouble they were,but honestly i havent had any problems.I still have combinations i want to try but i like where its running at with 1t on the memory and 2.5 cas,but i will probably see what she will do after i get the water cooling system done,just waiting on the Fed X guy.lol.If i get her higher i will be back..
"If it aint fast enough,overclock it"
Stonecoldkilla
Well i tried to get the file size down so you will have to expand it...
I looked everywhere for a revision # but couldnt find it. Here's a link 2 what i bought. Is it Bh-5?? Should i return it and get something else. I am pleased with the current performance but im wondering if i can get more. I see these other people with 800 dollar chips and they r only getting like 4-5 seconds difference in super pi than what i am getting with my 150 dollar chip so i am quite amazed.
Overclocking is great!
http://www.newegg.com/app/ViewProduc...145-521&depa=0
I am getting 35sec at 250x10.0 1:1 @ 2.5-3-3-0-1T
I wonder if I can tweak the ram alittle bit more...
My latest cpu
together with the msi motherboard and dual set corsair 3500
super PI takes about 28 sec
http://www.tweakers.net/ext/f/45405/full.jpg
http://www.tweakers.net/ext/f/45570/full.jpg
tomorrow i get OCZ 3200 rev 2
A64 3200+ newcastle cooled by VapoChill LS (shot) and by Mach 2 @ r404 (superpi)
http://utenti.lycos.it/swarzy85/frequenza_max_vapo.jpg
http://utenti.lycos.it/swarzy85/Imma..._freq_prom.jpg
A64 3700+ Clawhammer cooled by Prometeia Mach 2 @ r404
http://utenti.lycos.it/swarzy85/Imma..._superpi29.jpg
(shot @ 3065Mhz)
http://people.freenet.de/funkflix/32k01.jpg
My settings for 3DMark01 benching! :)
Peter,Quote:
Originally Posted by petervandamned
That's the stepping I'm looking for. Where can I find someplace that will send me a particular stepping? I'd be willing to pay them a few bucks extra for the stepping I want. Thanks....nice chip btw :D
Sorry Dude got the cpu not from a store. I was from a used section, but was brand new in fact.Quote:
Originally Posted by TheDude
It's so hard to get your hand on good steppings
Ain't that the truth! I had 2 good contacts...both have moved on to bigger and better jobs now.Quote:
Can you SuperPI 1M for me...thanks :)Quote:
Originally Posted by GravediggA
http://people.freenet.de/funkflix/pi295.jpg
It's an bit older, but i hope ~ 2900 MHz is enough! :)
An nice screenshot again! :)
http://people.freenet.de/funkflix/3ghz.JPG
Someone should give me an Vapochill! :p:
SuperPi 1M runs with 2935 MHz but no way to get 28 sec ....
with 1 stage phace change :D
3200+ 130nm@1.66V
Vapo LS
..only a test with my new CPU (first boot with this CPU) :toast:
http://koti.mbnet.fi/dani69/DFI%20nF...Hz%201.66V.gif
ok this my result no too good,any advice to make the fsb and clock more high?
http://www.flickr.com/photos/1381176_7396b32a28_o.jpg
Cant get it stable though. It won't pass benchmarking. I got it on the highest vcore that my mobo will support. Anyone got any idea's how to make it more stable? I am running stock cooling, and surprisingly it stay's around 32C. Sorry for the small pic. It's 2.7ghz at 1.7Vcore. With 300htt
Whats going on with the newcastles I'm thinking about ordering my 3rd. What are the newer ones clocking on air?
caa2c 0438tpmw
1096142I40373
fx55 @ -70c DI cooling - chilly1 spiral block container
http://pic8.picturetrail.com/VOL256/...6/75028457.jpg
I got 2716Mhz from a 3800 @1.56 core and just about stable 4 hours constant benching) using waterchill cooling (not idea ram, board was older then MSI neo2 Plat. I hear its better now
65416 plus in AQ3 using a unlocked and clocked ATI X800 VIVO also on water chill 536/495 47Oc (water temps@ 45Oc)
I had to set the speed at 2.545 as its a on sale system just hunt the user name for specs and details
Just got an A64 3000+, Winchester with MSI Neo 2.
0441 SPMW. Using W/C set up.
2.75Ghz Stable.
http://img.photobucket.com/albums/v1...4/3000-250.jpg
Prime for 55 mins.
http://img.photobucket.com/albums/v1...rime-27Ghz.jpg
I've just got my new set: A64 Winchester 3000+, Epox 9NDA3+ and Zalman 7000A AlCu - all on air.
http://www.geocities.com/ivanltd/300.jpg
Pime, pifast?Quote:
Originally Posted by IvanLTD
I'll post it latter tonight. Not enough time last night to do everything. :(Quote:
Originally Posted by htkm1
Does early 3500+ winchester have problem with its build in memory controller? Just received mine and it's a 0437 :(
heres my 3200+ (without this beautiful Heatspreader,thx @p4z1f1st):
2600MHz @1,34V
2700MHz@1,45V
2750MHz@1,5V
2800MHz@1,6V all primestable
http://mitglied.lycos.de/freestylerc...64%203200+.JPG
http://mitglied.lycos.de/freestylerc...4V%20prime.JPG
http://mitglied.lycos.de/freestylerc...%20Pi%201M.JPG
http://mitglied.lycos.de/freestylerc...5V%20prime.JPG
http://mitglied.lycos.de/freestylerc...00MHz@1,6V.JPG
greetz from germany
free
Lol!? And p4z1f1st can't get it over 2600MHz! :D Thats really funny! :cool:
freestylerrcs wow really nice clocks that 43C load right? What kind of cooling and any chance you can give it a shot @ 1.7V for us :D
Only watercooled by EVO 240+Zern 120
@grave yes, pazi just move it to 2600. But i think your CPU drives a bit better,or not?
@pulsar hmm, i'll try it tomorrow, but 1,7V, hmmm
free
Dunno, don't like Prime95! ;) One time i tested it with 1,57V @ 2817MHz andQuote:
Originally Posted by freestylercs
it gaves me an error after 30 min!
ADA3400AEP4AX
CBAZC 0435XPMW
1094922140518
1.68v
Air cooled
L@@K this is my last and final overclock. Unless i get some vx memory i think this is all my board (DFI ut250) can handle. All on air with a zalman 7000cu Heatsink.
:toast:
http://img12.exs.cx/img12/7050/86-ultimateclock.th.jpg
A64 3200+@2922MHz on air.
CBBFD 0433SPMW
