that looks really nice prospect :up: but the white LEDs at the top are a lil bright for me
my setup (while its still on air) :yepp:
http://www.rb-servers.nl/lawrence/misc/IMG_1741.JPG
http://www.rb-servers.nl/lawrence/misc/IMG_1744.JPG
the postman could bring my liquid cooling parts any moment now, hopefully I'll post in the watercooled case gallery next week :D
Took a couple of pictures for a friend this evening. Going to take some better pictures later. ;)
http://i273.photobucket.com/albums/j...0/IMG_6441.jpg
http://i273.photobucket.com/albums/j...0/IMG_6445.jpg
http://i273.photobucket.com/albums/j...0/IMG_6450.jpg
Here is my current setup with some pretty X-treme air cooling
http://img122.imageshack.us/img122/9820/1002486di3.jpg
http://img183.imageshack.us/img183/1532/1002487og7.jpg
http://img183.imageshack.us/img183/8687/1002491dz6.jpg
YAY I just my Delta Ultimate high speed fan :D :woot:
And WOW the thing blew a full tissue box over 30cm :p:
I haven't hooked in up into my rig yet, i'll do that tommorow morning and i'll have a look at how much my temps go down. I'm hoping for like 3C or lower.
Anyway here's some quick pics.
http://i292.photobucket.com/albums/m...yDeltaFan3.jpg
http://i292.photobucket.com/albums/m...yDeltaFan1.jpg
http://i292.photobucket.com/albums/m...yDeltaFan2.jpg
you brough some babies :) just got some FFB1424UHE will set them up in the rig this weekend but a taster...
First a picture of one of the new 140mm Deltas next to one of the old 120mm these beasts are huge and weigh a lot!
http://i266.photobucket.com/albums/i...r/DSCF4215.jpg
As I have pre mounted the seperate 24v powersupply and two 24v PWM control units in the case had to rip the rig to bits and run the video's with the delta sitting on the top of the case... will need to sort some longer wiring at some point... also in my rush on the way home I forgot to pick up the tri-pod for the Digital Camcorder so I apologise now for the unsteady video's! had to use one hand as the other was controlling the PWM units
First video is one fan setup on one of the 24v PWM controllers... have the multi-meter in the for ground so you can see the voltage going through the fans, here
Second video I have two fans running off the same controller.. had to tape them down :) can be seen here
To give you some idea how much air they are pushing had a lighter on the desk about 5 foot away that promptly blew across it :)
nice rig ^^^
+1 very clean rig you got there
Thx. :)
about 5.5k RPM @ 24v, the fans have RPM leads so will connect those up to some 3pin headers for readouts when I install it all.. might get close to 6K RPM running them at 27v out of the powersupply (fans are rated at up to 26.5v) give some overhead for the loss of power through the PWM units
They will have fan gaurds on the intakes and be ducted in the end so no chance of lossing a finger :) bad enough catching your finger in a 120mm delta
nice and clean illidan
New addition to the family, the new NB fan:
http://www.dzikie.net/artykuly/3dcoo...47u/big/69.jpg
:up:
nice :)
where did u find it ?
very nice & clean Sagart & illidan! :up:
@illidan HG Spot.:D I just didn't use it for a long time.
Cant remember if I've posted in here so..
E8400 @ 4.0ghz + Thermalright Ultra 120 Extreme
2x2GB Mushkin Redline DDR2 @ 1068 5-5-5-15
xfx 8800GTX xXx @ 660 Clock 1061 Mem 1414 Shader + Thermalright HR-03, HR-11
Xfi Extreme Gamer
Seagate 2x500G Sata HDD + WD 75G Raptor
Enermax Liberty 620Watt
Xbox 360 internal reciever
themalright ultra 120fan cpu cooler
thermalright HR-05 80fan Chipset cooler
thermalright HR-03 8800 GPU cooler
thermalright HR-11 GPU Back cooler
5xNoctua 80's
1xNoctua 90
1xNoctua 120 CPU
Few pics:
http://i148.photobucket.com/albums/s..._6Enhancer.jpg
http://i148.photobucket.com/albums/s..._9Enhancer.jpg
http://i148.photobucket.com/albums/s..._2Enhancer.jpg
http://i148.photobucket.com/albums/s..._5Enhancer.jpg
foR, your case is just like The Dark Knight :). Very nice, but it seems like there's no place for anything else.
