p5b dlx revision 1.10g and 4gb of ram
do any of you have the p5b dlx revision 1.10g boards and 4gb of ram and qx6700 cpu?
i have built 2 systems this week with 4gb of ram and dual boot systems with xp pro and vista 64bit. in the bios i enabled the remap so i see 4gb of ram and vista 64bit is happy but xp pro is only showing 2gb.
normaly with the remap enabled i see 3.2gb in xp pro.
if i disable the remap i do get 3gb in xp pro.
on older versions of the p5b dlx with remap enabled or disabled i see about 3.2gb
the bios version is 1101.
