tadzik1231 your watercooling liquid is white?
What brand is that?:up:
tadzik1231 ive seen every page of this thread and that's one of the sickest setups yett. i'd love to see more pics, maybe one of the whole case?
Yeah, it's white like a snow/milk/lime:
http://j.imagehost.org/t/0924/B_W_000103.jpg
You can find it here (and probably only here): Click. I saw somewhere Mayhem's approach to white nano but it's not ready yet.
Look here: Click, and it's not my last word :) have got some new ideas (double B&W GTX 570 + double pumps + double rez). I'm just anxiously waiting for a few parcels.
Thanks, scgt1. About time for another REMINDER ...
Also - please keep questions and discussions to a minimum ... feel free to PM or check out worklogs. This is not meant to discourage communication, just trying to keep the thread manageable as an archive of finished water cooled systems.Quote:
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
Blackstare...very nice, are you planning on painting the inside black?
"New Blocks on the Kids".... Gigabyte GTX 580's:
http://img717.imageshack.us/img717/7567/dsc1026q.jpg
http://img839.imageshack.us/img839/9111/dsc1027f.jpg
http://img28.imageshack.us/img28/8621/dsc1029m.jpg
http://img694.imageshack.us/img694/9121/dsc1030x.jpg
2 weeks ago i upgraded my old Q6600 setup to a i7 setup. Today i finished the last details.
http://tweakers.net/ext/f/meSZazwOa8...okS4h/full.jpg
Hi Everybody
any photos about mine (sorry for my english, french people inside), this is my first built :p:
http://img607.imageshack.us/img607/3452/p1110358.jpg
http://img51.imageshack.us/img51/6978/p1110359o.jpg
http://img819.imageshack.us/img819/1...itier12.th.gif http://img210.imageshack.us/img210/6...itier32.th.gif http://img109.imageshack.us/img109/9...itier42.th.gif http://img823.imageshack.us/img823/1...itier82.th.gif http://img21.imageshack.us/img21/7983/boitier92.th.gif
http://img714.imageshack.us/img714/1...tier102.th.gif http://img717.imageshack.us/img717/4...tier122.th.gif http://img834.imageshack.us/img834/7078/cg2.th.gif
thanks to XTrem's members for all pleasure and ideas you give me with your systems :up:
@ snipeangle :shocked: :up:
did u paint the fittings and the part of the card block white? also what store u guys buy all ur tubing/water/waterblocks from online? is it frozencpu? and also the sleeving kits...im duying to do thatdo u guys use a special tool to pull te pins out from the connectors? cuz i tried it to a mini screwdriver but it ended up ruining the pins inside the connector
i did some sleeving on my system, still not finished yet though. i still have to do the 24-pin power. i bought all the sleeving and pin removal tool from performance-pcs.com
i got this sleeving
and this pin extraction tool
i had a bunch of heat shrink at work so i didnt need to buy any, but i used 1/4" 3:1(1/4" before shrink, 1/12" after shrink) black heat shrink and it worked out real well
snipeangel: what CPU waterblock is used in your build?
@ jedihobbit, I don't know if it's for me but if it is, thanks a lot ;)
@ churchy, it's an old Enzotech Luna, it works fine IDLE 36°C and 64°CMax with 1.38V for VCore :D
@PilatuS, that's some epic insulation you got there :eek: :rofl:!
No offence but:
"I said it before
I'll say it again
If you could just listen
Then it might make sense"
Offspring - All I want
No quoting pic. :up:
- compressions (Feser) powder coated RAL 9016, threds have to be protected
- rotary (Bitspower) aluminium grey primer + "sleek" Motip RAL9016
- GPU block powder coated RAL 9016, surfaces resposible for heat conduction, threds and spots under standoffs have to be protected
That is my watercooled striker II extreme .......and I think to go for Chilled cooling soon:D
kids lighting small tweaks you like?
http://img262.imageshack.us/i/11012011067.jpg/
http://img130.imageshack.us/i/11012011066.jpg/
http://img98.imageshack.us/i/11012011065.jpg/
My monster :) still want to change my motherboard sometime or another :) but it,s fine for now :)
