pencil mod success - kinda'
I did the pencil mod to controll the vdroop I get on this board and it worked! Thanks guys for all the instruction/pictures. I have my board set to 1.5375 and it would droop to 1.49-5v. Now it stays between 1.54 and 1.52. I even squeaked an extra 50mhz out of it now!
I can't get much higher though because it seems that when I raise the voltage the droop increases a bit. Either way, thanks for the help! can't complain about the results.
One question though, what happens if I put too much graphite on the resistor?
help with AHCI/harddrives
i have an issue with the setup im trying to run. the issue is that i have 2 seagate 120gb drives i want to use as storage, but vista ultimate see's them as one combined drive that is unreadable and unallocated and in disk management all the options to format/partition/etc are greyed out. whne i look at the properties it has the disk labeled the same way i had them about a year ago when they were raided together! is there something i need to change to get them to be seen as individiual drives? i have tried every combo of things i can think of, its drivin me nuts lol
right now i have AHCI selected in bios. on the red adapter is my raptor 150gb with vista, on the black next to the red is a wd 500gb backup drive. on the next black is a 120gb seagate, and on the ezraid 1 is the other seagate 120gb. i have removed both jumpers from the ezraid currently, but have tried this in all the jumper configs trying to get SOMETHING to let me access the drives. the only thing that would let me get on the drives is using the jmicron, but i can only see the one drive on jmicron and not the 2nd drive on either the black or orange connectors when i do this. the raptor and wd 500gb always show up just as they should.
is this because i have ahci enabled? does something in the mbr (i dont even know what that is really lol) of the seagates need changed?
help please:eek:
