Hellos, some pictures of my TJ07, forgive my bad English
http://www.abload.de/img/dsc049546el9.jpg
http://www.abload.de/img/dsc03548doa8.jpg
http://www.abload.de/img/dsc05019ygf3.jpg
http://www.abload.de/img/dsc048619gdj.jpg
^ forgiven :)
Very Nice and the dust just indicates that it is a working system!! ;)
The red fan at bottom right for the HDDS? Also two loops, large up and small down? :shrug:
@ gogofr......nice and simple, one question, why such a large reservoir? It is my understanding that they are for refilling and they only need to be just large enough to keep the pump from cavitating?
Still looks good though! :D
My first water cooled system.... Took me forever! ;-)
http://www.3dchipset.com/pc/mypc1.jpg
http://www.3dchipset.com/pc/mypc2.jpg
http://www.3dchipset.com/pc/mypc3.jpg
http://www.3dchipset.com/pc/mypc5.jpg
Great work, 3dchipset :up:
Thanks Shazza, means a lot.
You have a buildlog 3dchipset? Is your case powdercoated or spraypainted? Nice system!
love the loop layout 3dchipset! TJ07s are a dream to watercool :yepp:
Actually I don't have a build log for this PC... I basically started in July and would work on it every few days until it was finished last week. The case is powdercoated.
The system contains,
ek Supreme HF CU block
ek Rage III Extreme Northbridge/Southbridge Full block
ek 580 GTX Nickel Back plate
ek 580 GTX Nicke/Acetal GPU block
XSPC Quad 120 Radiator
4 x Gentle Typhoon's 1500RPM fans
White 1/2" x 3/4" tubing (Primochill brand)
IandH StealthRes 225 reservoir
Bitspower Shiny Silver & Matte Black 1/2" x 3/4" compression fittings
Intel 980x Core i7 @ 4.2GHz
Asus GeForce 580GTX
Asus Rampage III Extreme
Corsair 6gig memory
Corsair AX1200 Modular powersupply
Swiftech MCP655 Pump with Bitspower Matte black shrouding
Silverstone TJ07 with Murdermod backplate & Powdercoated throughout
Took about 5 months to save up for all the goodies.
Lanboy Air ... i7-950 running at 3.9G
http://www.treasure-cove.net/LA8.jpg
I was going to install the Swiftech Edge 240 Kit, ... but I would have had to do some majjor re-work of hte case to get that one to fit, .. so I opted for the Coolit ECO C240.
http://www.treasure-cove.net/LA9.jpg
http://www.treasure-cove.net/LA10.jpg
Still have a few more things I want to do.. right now, under load, the temps are running 67-68,... so I'm going to install 4 Sythe Kraze's Push-Pull and see if that will get the temps down in teh low 60s.
Your case reminds me of the ASUS Ares... go get one haha
http://www.hardwareheaven.com/review...res_5870x2.jpg
Very Nice@3dchipset
Hello Boys,
this is my new PC with Efi-X with operating system Mac Os-X 10.6.
Lian-Li TYR 900 Red Edition | Gigabyte UD5 | Xeon WS 3520 | Corsair Dominator GT 12 GB | Tubing 19/13
Fabiostory cool system :up:
My 1st post here on XS,
My Square1 system:
http://img59.imageshack.us/img59/110...491024x768.jpg
http://img708.imageshack.us/img708/5...451024x768.jpg
http://img24.imageshack.us/img24/580...361024x768.jpg
http://img180.imageshack.us/img180/8...591024x768.jpg
Hope you like :)
P.s: sorry for the watermarks, but a long ago i had some photos "stoled" so, don't give another chance :mad:
You should just do an embedded and encrypted watermark instead.. that way it doesn't ruin your photo, and if you want to take someone to court you'll win when you present your encryption key which unlocks your watermark on the lower bit layers.
Second incarnation of Black&White in my small Cosmos:
http://g.imagehost.org/0675/B_W_000114.jpg
http://j.imagehost.org/0576/B_W_000117.jpg
http://j.imagehost.org/0186/B_W_000119.jpg
http://j.imagehost.org/0111/B_W_000120.jpg
I have to change my signature :p:
that is SsssTunning!
if only i had the coins :)
