damn vkbms, I think that's a first for d-tek GPU and the best v2000 build :)
it's the best way i've seen to hide the psu wires
um.. i think the hole size is like 2 or 2.5 inches can't remember
i sold that case on ebay for 220
had like 400+ in it
Here's my first foray into the WC world...
http://img179.imageshack.us/img179/6525/img6454qp1.jpg
http://img179.imageshack.us/img179/6126/img6469tk0.jpg
http://img179.imageshack.us/img179/2994/img6464kr0.jpg
nice looking cube...but get rid of the IDE tag....lol
Aging 939 in a beautiful case...what could be sexier? :D
Never though I would say this but those coils look kinda good
LOL...not a huge fan of coils either...but they do look ok in that setup...
Pinmod where did you get those from
http://i187.photobucket.com/albums/x...crework031.jpg
Petras Tech Shop sells them too.
It's an Aqua Computer aquaero LCD display.
Brendan
yea i think it was ace hardware
that was my first build .. little slopy :)
http://benstyle.be.funpic.de/new/sideno.jpg
http://benstyle.be.funpic.de/new/side.jpg
http://benstyle.be.funpic.de/new/ekmounted.jpg
Todo:
- Add two more cfl Cathodes (White)
- Cablemanagement
Hope you like it :) And yes it isnt a Lian Li. Its a Aplus Black Pearl based on the LL V2000B ;)
running clear huh?
edit: damn that is sexy
nice, what size tubing is that?
BeeN: what temps are you getting on your E6600 with that EK Wave, also, what are your room temps??
Hi guys. Its 15/11mm Tygon. My E6600 is running at 33-34°C with no overclocking and my room temp could be 19-22°C :P
Greetings
I decided to move my loop internal (was using a modded Nautilus 500 previously).
This is a first time build for me (internal that is) and I kinda like it. I think its pretty clean. Pump and res are fixed on with velcro so that if I need to slide the mobo tray out, I can do so with the pump and res. :D
Pump is a DDC, radiator is a Coolrad 12T and block is the Dtek FuZion. Used 3/8 ID clearflex tubing.
Case doesn't have a lot of space (not exactly ideal for Watercooling) so I'm pretty happy being able to squeeze things in. :)
I don't mean to be pedantic but I wouldn't call that internal, its sort of half way.
Get the rad inside, THEN it's internal :)
Been, are you using TAT or Coretemp?? Are Thermochill PA120.3 really that good?
@Been: Very nice case, looks really good!
