Originally Posted by
Nuckin_Futs
NO, reverting did not help me once I did go v0907, and from what I understand on RAMPAGE BIOS, this will void your warrenty (correct me if it has changed). But nevertheless, you're only opening the door for more problems if using a BIOS written for another mobo. So if doing so, do so at your own RISK.
I had to RMA mine to get back to normal after the bad v0907. I know others have used it and claim no issues, so again, as with any beta BIOS, nothing is guarentied. Either mine was an isolated case or nobody wants to report it.
As for the cooling, totally understood, thats why I gave the idea of modding with things around the house, some plastic and cut and shape a duct for the NB and put small 40x25mm fan either to case rear exhaulst or on front end. Abit used this method on their early OATES system to cool mosfets and it did fine on air. I still have the 1st IC7-MAX 3 and changed the mosfets blocks to copper.
