please do stay in touch here eye wanna see if that kind of volts kills :D
no really !!:up: thinking of going thier my self but for 5.0 for 1.5v
is Q750A071 a e8500 or a e8400 on dope? lol just wondering cause i was looking through the batch numbers and can only find Q750A batches for e8400....
My new Q816A passed OCCT 1hr cpu test at 4.2 (8.5x495) with 1.33v bios set on my maximus formula.
Prime95 small fft failed at this setting in 1hr 18 minutes.
Now test 4.2 with 1.35v bios set. I really wish I could find the vcore reading point for this board so I knew the exact voltage since this board droops.
the bes way i can describe it :D
http://images.google.gr/images?clien...89%CE%BD&gbv=2
E8500 Q744A746
http://i287.photobucket.com/albums/l...l1/1066CL4.jpg
Q816A092
E8400
Asus Maximus Formula Bios 1201
2x2GB PC8000 4GBPQ
Watercooled
1.35 volts bios (actual unknown)
http://www.johnshim.com/forums/xtrem...z1.35bioss.jpg
so it looks like my e8500 805 batch according to the bios (i just set it up) says at stock speeds its 1.22v?? is that not high for stock settings??
So ive Cracked 600FSB and Sub 9 SuperPI check it out, some pics
These are before .... prepping my board
I spray painted my mother board back and front around the cpu socket with Clear Laquer
http://i161.photobucket.com/albums/t...ture001-42.jpg
http://i161.photobucket.com/albums/t...ture002-41.jpg
http://i161.photobucket.com/albums/t...ture003-35.jpg
http://i161.photobucket.com/albums/t...SP_A0694-2.jpg
http://i161.photobucket.com/albums/t...SP_A0689-1.jpg
Add some Alcohol, give the Dice about -20 + onto what it is at -55 so thats -75 to -87 degrees
http://i161.photobucket.com/albums/t...SP_A0687-1.jpg
And now Some Benchies
http://i161.photobucket.com/albums/t...l_018/8875.jpg
http://i161.photobucket.com/albums/t...0FSB12812s.jpg
Some rig shots
http://i161.photobucket.com/albums/t...ture007-20.jpg
http://i161.photobucket.com/albums/t...ture006-25.jpg
http://i161.photobucket.com/albums/t...ture004-36.jpg
Then Idle Temp
http://i161.photobucket.com/albums/t...SP_A0693-2.jpg
W00t.
Thats all for now.
How much NBv does 600 need? Do you have a thread for your MB? Link please.Quote:
Eish i crapped myself, luckily for that spray paint.
Check this :banana::banana::banana::banana:
http://i161.photobucket.com/albums/t...icture0013.jpg
http://i161.photobucket.com/albums/t...icture0031.jpg
http://i161.photobucket.com/albums/t...icture0022.jpg
My pc didnt work for a lil while. for some reason i can run my ram in Dual channel, what could be the problem....screwed up the NB a bit maybe...
Comments are welcome
Found its sibling at DriveCity, Germany.. ;)
Nice serials both of them..
http://img67.imageshack.us/img67/187...08smallmm4.jpg
My batch # is hiding under my zalman.
http://valid.x86-secret.com/show_oc.php?id=387003
http://img79.imageshack.us/img79/5493/40passbv2.jpg
i just got my Q813A E8500 from the egg. Priming large at 4275 (1900fsb) 475x9 now will post more when i drop voltages. My Q807 E8500 runs 24/7 at 4275 1.42v post degradation. I just dropped the new chip in and dropped vcore to 1.35. been priming 30mn. If this runs 45min i'll drop volts and raise FSB some. bbs
well i got a crap chip i guess. my vid is 1.225 and ive reseated the heatsink 3 times now vertical and horizontal and my core 2 temps is nearly 5-6 deg higher than core 1 under any stress.. ive tried mx-2 and as5 also.. why cant i ever get a low vid chip.. arghh this sucks batch was Q805A500 and i just freaking got this one from newegg and everyone else is getting these nice 817's or 816's and why the heck i get this thing..stock voltage with cpuid is 1.235v already
i also think one on the temp sensors is getting stuck. core #0 seems to not move at all when i check the sensors with real temp where core#1 jumps up and i get about a 5-10 difference in the sensor test between cores???
Im going to get a 8400, which week should I try to find?
Ill use with a p5k moded, how will it work?
Thanks for help.
Excell OC list (not 100% up to date)
http://users.pandora.be/OAP/wolfdaleOClist.xls
with core temp 99.1 it says 1.15 for vid. temps are fine overall im idling at 33-34 but when i load it i see core 1 jump fast and it takes core 0 a while if sometimes at all for the temp to rise..even with core temp it appears core 0 just sits there temp wise until a large increase is needed but at idle it reports both cores within 1 deg of each other.. its just that core 1 will say jump to 48 where core 0 sits a idle temps then when core 1 hits just over 50 core 0 will finally jump up also???? and core 0 will never go below 34 deg ever.. where core 1 will drop to maybe 32-33 at idle.. it juts looks like core 0 is locked at 34 all the time till a large temp increase is shown. so do i guess i have a bad temp sensor huh??
so is 1.15 decent for the vid on these??
Swapped my Q6600 with my baby brother's E8500 on the offchance that it might be a good one...
Turns out it was a Q745A809 purchased back in February, I'd heard good things about the Q745A's but when I got it installed I found it had a pretty disappointing VID of 1.225 :shrug:
Anyway messed about with it a bit and got this:-
http://i135.photobucket.com/albums/q...FFA22/4250.png
Might ebay it and try something else.
Ok. I think I finally got my overclock stable. As you can see from the pics, it passed a 5 hour small FFT test in Orthos and I just started a blend test to make sure that the ram is stable. If all goes well, I will try for a 4000 Mhz overclock later today.
http://i306.photobucket.com/albums/n...ck-3500Mhz.jpg
What do yall think of the Vcore? It seems like this chip is a pretty good overclocker. Batch Q815A418
The temps are a bit high, but after I lap my heatsink and processor, those should go down.
I know that when you run Large FFTs, the 5 minutes are crucial for the ram ...if in this minutes you don't have any error, you have 99% stability on u're ram...that's right ? :D...anyway...
Vcore 1.33 bios (i lowered the Vcore)
Vcore idle 1.280
Vcore under LOAD 1.208
Ram at 980 mhz 5-5-5-15 @ 2.1V
NB 1.4
PLL 1.5
FSB TERMINATION 1.3
Core Temp show me 75 degres and Real Temp show me 65 degres...my cooling is ZALMAN 9700CNPS (high RPM for test), the case is Tagan A+ Twin Engine...what degres are right?
