how did you get the 11x multi?
That's what I was thinking, please tell..Quote:
Originally Posted by ncc-1709
Ahhh, so you're the one with the WR and the 11x multiplier. I went to check what I had to beat to get the WR on this thing, and saw 11xblah, and was like "No fair!". :p: Please, do tell.
He just had luck and got a CPU with 11x multiplier opened.
hit the nail on the head...i have a 0546xpmw under water @2.8ghz 1.4725 voltage set in my bios. a8n32-sli m/bQuote:
Originally Posted by alpha0ne
it can do 2950mhz but takes upwards of 1.56+ volts to get there.
anyone got any data on the CCBWE 0609 FPAWs? i cleared out my CCB1Es of the same stepping, but have these 3 left. evidently the same shipment that my parts came from are sitting in AZ...garrrrr...must resist buying more!
PM would be appreciated.
dave
dave I've looked at your web but seems like its outdated. Also the pricing list is no more on the server (that's what it says, 404). Have you moved it or something? Thanks!
lolQuote:
Originally Posted by mursaat
yeah...sorry, trying to move pricing over to the new store front, etc. if you hit the forums you can always get pricing.
sorry!
dave
Hi Dave:D
Any signs of more of those CCB1E coming in?
guys, in deference to the rules and regulations of this forum (and my desire to not get banned) please shoot me a PM.
dave
Noob warning!
Hey guys, I have problems getting my 165 0551WMPW to any decent speeds.
Above 230HTT and system wont load XP. I tried with up to 1.45 vcore.
HTx3, ram 266. Decent Antec Neo Power 430W PSU. ASUS A8N-E mobo with the latest bios.
People seem to be getting atleast 2.5 with 1.4vcore with this stepping :/
Also Cpuz and other apps always display the CPU as running at stock, even tho it is overclocked in the bios :confused:
http://www.sourcekills.com/albums/ts...de/priming.png
Someone called me out on my chip, so I made a screen of where it's at so far, as of this morning. It's nothing really good, but it's something to prove where I'm workin' at isn't total BS. ;) Of course ambient went up 10F today, from 65F to 75F. :( I just can't get a spree of good luck.
That's not true. Two I've tested won't do 2.5 GHz without 1.5V. On air, you'll be lucky to get 2.65-2.7 and 2.7-2.75 on water, 2.8 tops. I wish I had waited and gotten a new 0608. Why does AMD have to release some :banana::banana::banana::banana: stepping in between 2 good ones.Quote:
Originally Posted by Lord KneeGrow
Got bored. Suicide run with 1.5v, I'm 100% positive heat is the limiting factor now.
http://valid.x86-secret.com/show_oc?id=82765
No 11x for the first 6 weeks I owned the chip (I checked).Quote:
Originally Posted by neoman
I was thinking recently, and just before I put it under phase for the first time (with no IHS by the way) I covered the SMD resistors and the exposed contacts on the package with nail polish, just standard clear nail polish.
Put it under phase, as a larf I checked and wow 11x multiplier.
Dinos22 also put nail polish on his SMD's, before ever putting his chip under phase, and got 11x I believe.
so you can unlock 11X on what chip?]
Think it would work on a 170?
i doubt that had anything to do with our chips going nutsQuote:
Originally Posted by Nephilim
i'd say it had something to do with phase maybe or RAM used.......
i have a kit of OCZ RAM which will force the chip back to 10xmulti and after cmos clear i get the multi back with a different stick of RAM.....something odd....but my 11xmulti is here to stay for sure :)
nice lapping btw.....mine is not even close to that but it's flat enough hehehehe and damn i had blisters for a few weeks after I was done lapping the IHS on its own heheheheh :slapass:
So I have to ask, what color did you guys use on your Opterons? Did it match it's outfit well? :ROTF:
I am getting ready to mount my new Thermalright XP-90C heatsink, but am planning on lapping the two mating surfaces first. I have never done this before, but think I understand the basic concepts. I plan to do the following:
1) purchase wet/dry sand paper in grit ranges from about 600-2000
2) mount the sandpaper on a flat surface
3) progressively work up through the ranges of grit to eventually achieve a mirrorlike finish
4)finish off with some sort of metal polish (I have both Brasso and Autosol paste)
The lapping process will be done by applying light pressure to CPU and heatsink assemblies, doing no more than three strokes at a time in any one direction, and varying direction so as to sand in all 8 points on a compass.
After the final polishing is done, I will clean both mating surfaces using the new two part Artic Silver cleaning solution.
I will apply a super thin layer of Artic Silver Ceramic thermal compound between the mating surfaces to enhance heat transfer.
I have a 20" x 48" x 1" thick piece of plexiglass I was planning to use as a mount for the sandpaper. It is apparently flat (smooth to the touch with no surface abrasions), and has enough room so I can mount all the necessary sandpaper in a row.
My questions are these:
1) Is my plexiglass a suitable surface to work on, or should I get an actual piece of plate glass? Would glass be a flatter/ better surface?
2) Is it safe to lap the IHS while it is still on the processor, or do I need to remove it and then remount it later? I will be using the black foam piece that came with the processor to protect the pins.
3) Is the process as I outlined it essentially correct, or should something be modified?
pink of course :p:Quote:
Originally Posted by tsuehpsyde
pics please. i just tried with some pink stuff to hand, but it dident work.Quote:
and a pic on the nail varnish maby. please. it could be the cure to my cpu problems(other than having to make a new chiller)
Posted this over in the opteron thread... meant to put it in the dual opteron thread....
I just got my new CPU and want to start overclocking.
some specs...
Asus a8v deluxe
2gb corsair TWINX2048-3200 3-3-3-8
Antec 480W True Power
Thermaltake Tsunami Dream Case
some stock non overlclocked settings
2:1 DDR 400
bank interleaving AUTO
Burst Length 4 beats
CAS 3
TRAS 8
TRP 3
TRCD 3
TRRD 2T
TRC 11T
TRFC 14T
TRWT AUTO
TWCL AUTO
TWR 3
aysnclat AUTO
read preamble setting 5.5ns
2t command DISABLE
CPU FSB 200mhz
CPU mult 10x
CPU voltage 1.350v
agp/PCI 66.66/33.33
vdimm 2.8v
Seems that the ram and cpu combo are a little sensitive. Any suggestions on how to relax the RAM timming so I can get a decent overclock and still get past system post.
All your timings look about right, I think it is more the motherboard holding you back than the RAM and CPU combo. One thing to try for now though is set a bigger mem divider, until you can afford a better mb
U might wanna look into another PSU.Quote:
I agree on the mobo and the psu, whats your amperage on the 12V line?
