unless the 6100 unlocks to be 8100, and unless 8150 is lower voltage than 8120, everybody is just going to get 8120 :)
15% extra money is worth 30% extra cores. and higher stock speed is not worth $40 if they both overclock the exact same.
Well the 945 was later in the C3 revision a plain, normal 95W part. The first 940/945 models with 125W were still C2. Nothing exciting about that, that's the normal process/stepping optimizing benefit. If you want to compare it to FX, then my point would be that the 8120 95W model will be scarce as hen's teeth in etail, because it will be an OEM only model and etail=we have to live with the 125W part or the 8100 95W model, instead. Then next year, when they'll launch 8170, there's maybe enough 95W 8120 for everybody. We'll see...
With the previous launches (agena/thuban) there was a notable difference in overclocking between the top and lower models. And with the rumored somewhat limited production of BD, I dont think it too far fetched to assume the top model will be the one to get for max clocks this time around as well.
And with 8 cores, the chance of getting a crap core or two is not exactly smaller than before. So you'd assume binning plays and even bigger role than before. But yea, we'll see soon enough :D
Anyone heard about Windows 8 seeming to steer the cores better than windows 7 ? Current Task scheduler seems to mess up a bit the performance of our beloved BD... Looking forward to fire it up tonite...
I think we should call Zambezi 8150 an 8 threaded CPU. This way we avoid any core vs not-a-core arguments. It has 8 strong threads,according to AMD,so let's call it 8T capable CPU. Thuban is 6T chip,SB 2600k is 8T chip. Whether it's a weak or strong thread is debatable though.
On another note,we have some shops listing FX models and mobo and FX bundles. So it seems 12th is the date. Won't be long now :).
oh, I like this package....
Windows itself doesn't need to be aware of FMA4 and XOP for developers to use them of course. A Windows patch would only address what Windows itself uses which can increase core Windows performance.
Can we not get into the core vs thread thing again?
No, it was needed for AVX because it introduced new/wider registers. The OS has to save these between context switches now, too. Think about what would happen if the OS forgets to save your data ... *g*
XOP and FMA4 however do not introduce new registers, they use the SSE or AVX' registers, therefore no extra patch needed - as long as the AVX patch is in place everything is fine.
i see bundle package in extreme news section
Hmm exactly what I meant.
You wrote "improve with time", that's correct, hence I wrote "next year":
I don't see a problem here, only a misunderstanding ;-)Quote:
As long as these cores are only using good,old, standard-x86 registers, no problem at all ;-)
Look at the production date of that chip. "1136" that is september right?
I know, but it could be that perhaps some state attributes needs to be stored. Can't find where I've read about it.
Regarding task-scheduling, it's from JF-AMD:
Also, there were some slides on how Windows' scheduler needs to be changed to accomodate to BD, and IIRC it was about Win7. Can't find it now, either.Quote:
Performance is based on:
The silicon
The microcode in the silicon
The BIOS
The compiler updates
The drivers
The OS optimizations
Performance tuning by engineers
