Problems with Ali Booster and Adaptec Raid Card 2810SA
Well I currently have my system with a good OC of 3.5ghz. The chip I have in it is a E6600. I have run prime stable for 14hours and a full load temp of 72C. However the problem I am having is when I place my raid card in my system on boot up Ali booster seems to go nuts and give errors about CPU Resource 3. Does anyone know what could be cause my Adaptec 2810SA using one pci slot to act like this.
Trouble with heat sink mounting pegs?
Has anyone had trouble with heat sinks using the standard snap-in mounts on this MB?
I have a quad-core QX6700 and a CoolerMaster Hyper TX. (I bought an OEM chip without a heat sink.) I've been having some issues and I think they're heat related.
Backing up a bit: when I first put the system together, I wasn't planning to OC anything, so I used the thermal pad that came with the heat sink. A few weeks later the computer would stall on startup -- after a couple of seconds you'd hear a fan kick into high gear, and nothing further would happen.
I thought it might be the motherboard shutting down the system because of excessive heat, so yesterday I detached the heat sink, cleaned everything, applied some Arctic Silver, and remounted it. It immediately booted with no problems. Temperatures went from 70C idle / 90C gaming to 52C/70C.
(My theory is that the bursts of heat soften the thermal grease, improving the conductivity, so it needed to try to start up a couple of times before it really got going. Until then, the thermometer just shut the CPU down a second or two into POST.)
Today it had some trouble booting, and I'm seeing 57C/80C. I'm wondering if the heat sink is sagging in its mount and pulling away from the MB.
Has anyone else seen this sort of issue with a P5W DH Deluxe?
Any suggestions on heat sinks if this just doesn't work out? I prefer the snap-in kind, since I won't have to pull the system apart to attach a backplate, but I'm starting to wonder if that's workable with this MB.
My apologies if this question is a little low-powered for this forum. :-) I had the opposite problem with a different LGA775 MB -- I had to press insanely hard to get the pegs to set -- but that system hasn't had any problems.
