I tried to buy the ga-ep45t-ud3p p45 ddr3 mobo but it is discontinued! i heard that gigabyte will bring out new p45 ddr3 mobo in q2 2011
question: which is the best for OC the q9650? p45 under ddr2 or ddr3?
Well i jumped on the bandwagon and my batch is L037B486 with VID 1.30000.
I clocked it stable on 4050MHz, 60 degrees on load, cooling is a lapped TRUE 120.
Gonna go for 42xxish for 24/7 and than i'm a happy boy!!!
edit: nope, my ram is the limiting factor, on 460 it crashed and it isn't the power, i even tried 2.0Volt on my RAM and no difference. So now it is 4050MHz, well it does 57Gflops in IBT on 4050MHz, i see people with 4200MHz and they have 58Gflops.
I bought a second hand gigabyte ga-ep45t-ud3p p45 ddr3 mobo from ebay and it`s on it`s way to me! I will be using a pair of 2x2gb corsair xms3 dhx ddr3 1600 9-9-9-24 1.8v stock timings on the board. anyone knows if my ram will be good for overclocking with my q9650 on the ga-ep45t-ud3p? i did not opted for the ga-ep45-ud3p cause it is ddr2 and i have ddr3 ram atm. Is it true that the ga-ep45t-ud3p is picky on ddr3 ram?
Only way to find out is to try it out, is it a new Q9650 like mine, i bought mine couple of weeks ago, production date end 2010 with a high VID, i can't get mine over 4200MHz, i even bought new ram (dominator GT 2000MHz).
My proc needs in bios 1.49Volt but temps are not extreme, in IBT on 100% load it rises up to 67 degrees celsius.
my q9650 pack date is: 5/3/2010 with 1.2250 vid batch # L009B453 and bought it 9months ago
Yeah but i guess i'm done clocking on this one, 4200 is enough for gaming and ingame it gets 55-58 degrees max (temps are different cores) and i won't gain nothing much extra for going higher as in 4300 or 4400 for 24/7.
My next PC will get his ass kicked and will run like a b***h for 24/7, going for watercooling i guess.
socket 775..so dated..:shrug:..................i7 ftw.
Call of Duty: Black Ops GPU & CPU Performance In-depth
"Black Ops on the other hand saw a massive 78% increase in performance when clocking our Core i7 processor from 2.0GHz up to 4.0GHz, and we continued to see a performance increase right up to the maximum tested frequency. Both the minimum and average frame rates were affected, suggesting that users who are in need of better performance will want to overclock their processor for this game."
http://www.techspot.com/review/336-c...nce/page7.html
Thinking about selling mine. It's J0r3lbr's old chip.
Send it to me.
I'll take good care of him :yepp:
Hey guys, I could use some good old X48 advice. My CPU is a QX9770. I just installed 8GB of Corsair RAM (1600C8). My motherboard is the P5E3 Premium. As you may know, this board is quite picky with regard to settings. Currently the RAM is running at 1280MHz, however, it is rated to 1600MHz. FSB is 400 (default for this CPU) and CPU multiplier is 9.0 giving 3.6 GHz. I have been trying to increase the memory speed by upping the FSB. I have backed off on the CPU multiplier when the FSB has been increased. LinX is stable, and SuperPi is stable. However, at even FSB 420, I run into errors in Prime 95 at about 7-8 minutes. I have tried increasing the CPU voltage as well as the NB voltage to no avail. It continues to act exactly the same each time when the FSB is increased. What would you recommend that I change in order to get things more stable? It seems like it shouldn't be all that hard to overcome this, but I'm at a loss here. Thanks in advance.
While benching for the CountryCup 2012, I've managed to set a new record so it's time to bring up this old thread.
http://img213.imageshack.us/img213/4...perxptrefo.jpg
http://static.hwbot.org/images/cup-gold.png Q9650@4995MHz SuperPi 32m 9min 18sec 766ms
Damn nice work!
I miss my golden Q9650 :(
I'm back to testing my Q9650 while I'm moving to an Ivy Rig and it appears that the vcore selected in bios does not match the actual voltage supplied to the chip.
I'm monitoring power consumption through everest and now my computer shuts down at 235 Watts instead of its usual 210-215 W max in the past. Only reason I can think of is the mobo is no longer delivering as much voltage as shown in cpuz / selected in bios.
q9650 @ 4.5 GH v 1.425
http://i49.tinypic.com/sxna78.jpg
Q 9650 @ 4.6 GH
http://i45.tinypic.com/w7j5gz.jpg
http://i45.tinypic.com/2i6m068.jpg
^that is an awesome chip Gaul, what kind of cooling?
thx, CORSAIR H100 with 4 FAN
MAX CLOCK with safety volt 1.456 ( i quess )
http://i48.tinypic.com/o9e9ec.jpg
You guy shave done a LOT with this chip since i last checked things out. I've been running at 4.05GHz on a COrsair hydro since I last touched my bios with i think was 2011!.
I decided my last effort was going to be trying to take advantage of the memory clock abilities now that memory nativley hits 2400. So I picked up some Viper pc3-19200 (pv38g240c1k) 2400MHz 11-13-13-31 but i'm having some trouble getting it to run at anything beyond the last clock I had my slower kensington hyperx running at. here's my config. Hoping someone might be able to help me get this figured out.
Code:GIGABYTE GA-EP45T_USB3P
[u]MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: FAST
CPU Clock Ratio ..........................: 9X
Fine CPU Clock Ratio.....................:0.0
CPU Frequency ...........................: 4.05GHz GHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled] []
CPU Host Frequency (Mhz) ............:450Mhz
PCI Express Frequency (Mhz) .........:100Mhz
C.I.A. 2.............................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................:800 mv
PCI Express Clock Drive...................: 900mv
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 0ps
DRAM Performance Control
Performance Enhance....................: [TURBO]
Extreme Memory Profile (X.M.P.)........: disabled
(G)MCH Frequency Latch.................: [400]
System Memory Multiplier ..............:3.33D
Memory Frequency (Mhz) ..............: 1500Mhz
DRAM Timing Selectable ................: [Manual] []
Standard Timing Control
CAS Latency Time...............................: 8
tRCD ..........................................: 8
tRP...........................................: 8
tRAS...........................................: 24
Advanced Timing Control [Press Enter]
tRRD...........................................:AUTO
tWTR...........................................: AUTO
tWR............................................: AUTO
tRFC...........................................: AUTO
tRTP...........................................: AUTO
Command Rate (CMD) ............................: AUTO
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value......................:Auto
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)..................:Auto
Twr2wr(Different Rank)..................:Auto
Twr2rd(Different Rank)..................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control................:Auto ps
Dimm2 Clock Skew Control................:Auto ps
Channel A Driving Settings [Press Enter]
Driving Strength Profile:[AUTO]
Data Driving Pull-Up Level.............:Auto
Cmd Driving Pull-Up Level..............:Auto
Ctrl Driving Pull-Up Level.............:Auto
Clk Driving Pull-Up Level..............:Auto
Data Driving Pull-Down Level...........:Auto
Cmd Driving Pull-Down Level............:Auto
Ctrl Driving Pull-Down Level...........:Auto
Clk Driving Pull-Down Level............:Auto
Channel B
Channel B Timings Settings [Press Enter]
tRD Phase0 Adjustmen...................:Auto
Channel B Driving Settings [Press Enter]
{U]Motherboard Voltage Control{/U]
Load Line Callibration.........................:Enabled
CPU Vcore….???...........................:1.29375v
CPU Termination…...... 1.200V*...........: 1.260
CPU PLL…??????.........1.500V*...........: 1.5000v
MCH/ICH
CPU Reference.??????.........1.500V*...........: 0.823
MCH Core…????..........1.100V............: AUTO
MCH Reference..…...?.?.0.800V............; AUTO
ICH I/O…???....??......1.550V............: AUTO
DRAM
DRAM Voltage …?........1.500V............: AUTO
DRAM Termination ...…..0.900V............: AUTO
Channel A Data Vref ...0.75V.............: AUTO
Channel B Data Vref ...0.750V............: AUTO
Channel A Address Vref 0.75V.............: AUTO
Channel B Address Vref 0.750V............: AUTO
[b]{U]Advanced Settings[b]{U]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
Note: * refers to 45nm CPU
