Originally Posted by
chew*
From what I have gathered just skimming through temps, chips, vid, it appears the lower the vid the hotter they run but the less voltage needed to attain a high OC.
For instance vid on mine is 1.225 and does 3.2 with stock vid. With LLC enabled and real voltage set at 1.225 cpu-z reports 1.208, I only need 1.325v (cpu-z reports 1.308) for 3.6, and so on but my temps are peaking 80C with a scythe ninja knockoff.........I will have TRUE black 120 results tommorow or saturday. I don't think there is a max voltage per say because of Vid discrepencies, I would say that .2 over vid is safe for air 24/7 though.
