yup dot works fine too.. Artic Silver folks have tested all methods and the dot is the best according to themQuote:
And on naked core? I spread the TIM because I didn't know how much to put, it's a rice grain WITH IHS, but without? I got 4-6c, but it seems like few temp drop in my 165 after removing the top :confused:
You're supposed to spread the TIM on an open core, silly man. :p: You surely can't dot that little guy! :nono: Although, with ASC you can use a bead down the center which spreads.Quote:
Originally Posted by mursaat
Damn, the majority of the good chips don't make it to Australia.
For what it's worth, I decided to give auto voltage (1.35v) a shot again, and it seems to be doing very well. :cool: I'm testing 2.7GHz 1.35v right now, dual priming for about 20 minutes so far, loading @ 39C. :fact: Going to see how high stock vcore will take this thing, dual prime stable for at least 8 hours.
Originally Posted by tsuehpsyde
Gaaah gimme :) just orderd a 165 2 sec ago , after reading this thread for 2-3 weeks i couldnt be without one :) so hoping for a good stepping now.
will post results in 2-3 days :D
A table with all the OC's seems really needed here.
I mean, sifting away the gold from the dross in 3500 posts is a hefty challenge.
(will get my 165 later this week and I'll show y'all how it's done :D)
Hey pcdoc1 sorry for long reply timeQuote:
Originally Posted by pcdoc1
It's from monarchcomputer ;) They still have those 0609's there today , just got one more from them this morning to play with :D Will report back when after i test second one :toast: Testing on DFI SLI-DR right now , could be even better with Xpert ... The first one keeps amazing me more and more , it is DUAL PRIME STABLE 3.0GHz @ 1.50V on crapy water with > +53 C Loaded temps muahaha :eek: :woot: :fact:
http://img20.imageshack.us/img20/745...4mlffts1es.gif
Still on the rise, dual priming @ 2765MHz. :D If this thing gets to 2.8GHz, it verifies that heat due to a :banana::banana::banana::banana:ty IHS is the problem. Can I call it golden if I get 2.8GHz stock vcore IHS still intact with no lapping? :cool:
Ok , sorry guys made a typo yesterday it's not EPAW - it's realy FPAW :)
Opteron 170 CCB1E 0609FPAW , both of them .
First one , the one on the screenshot is the strongest it seems ... Second one that i bought today it's very good too , defenatly a +2.80-2.85GHz chip :)
The one on the left is the first one , and right one is the second :
http://img362.imageshack.us/img362/5608/0129qc.th.jpg http://img89.imageshack.us/img89/8157/0143hw.th.jpg
I like 06 chips :p:
I would most definately say so :DQuote:
I would like to see a really low voltage test, with something like 2.2GHz or so...I'm thinking of upgrading my small server/HTPC box to a dual and this might just fit perfect.
This stepping might just do it on 1volt or so.
I missed your previous post, but Holy PWMIC temps, batman! :eek: Get some cooling on there! You'll probably find higher stable clocks if you can get that PWMIC under control. ;) And prime died just short of 2.8GHz. :( Finding an 8-hour prime stable at least setting, testing 2765MHz atm.
I don't know what's wrong with my PWMIC temps :( , it gets that hot only if i use Vcore higher then 1.45V , i have a fan blowing on that area also :confused: , my PSU OCZ PowerStream 600W gets hot too , may be it's too much load (2x7900GTX , Dual Core .... ) , will try on DFI Xpert and see if it's mobo related or noQuote:
Gorod, you bought from Monarch physically cuz you live there, but for us non Georgians, did you buy OEM or Retail?
Oh i see what you are saying , they may ship from another location if u order online , i don't know but thats possible ... It's difficult to tell what stepping it will be . Both of them Retail package . Second chip (#293) seems prime stable 2.8GHz @ 1.4V so far :)Quote:
I got the CCB1E 0608 MPMW last week also. I was too busy with the 7900GT volt mod to do much. But these chips are defintely promising. As soon as I saw one guy say he got a CCB1E from Monarch I rolled the dice. It just felt right.
I only started it up and fooled around. For kicks I set it straight to 3000 with 1.4v and it went to windows. Still haven't even tried for stabilty so who knows. Only screenshots I have is when I was trying to figure out how much lower the mem divider was going to hurt, so I have those screen shots so I didn't have to write down the numbers. Stabilty will most likely be lower then this, but on my last 165 I couldn't get 2900 to not instantly BSOD at any voltage, so this is definetly a nicer chip. When I get the max stable I'll post real numbers. I just thought I should post and say these are looking to be nice!
http://home.comcast.net/~aicjofs/165.jpg
I noticed Core Center is still a piece of crap: "76 MHz x 39.0"
Is it just me or has every B1 chip you've seen been awesome
Sure is, but MSi stuff in general is blah. :p: This is x64, the x86 Core Center doesn't do it. Only app that I can reliably change mem voltage in windows. Also measures temps so I don't have to have speed fan open also. It's almost embarassing to have Core Center open in a screenshot. LOL.Quote:
AIC, you're switching from an Opteron 144 CABNE 0530 to an Opteron 165 0608 MPMW? Man, we're entirely too much alike. :) Your temps seem better than mine, but how did you get a 39x multiplier!?!?!?! ;)
tsuehpsyde, did you get your 165 from Monarch?
I'm looking to get a 170 from either Newegg or Monarch. Anyone have an estimate of the new steppings and which of the two companies I should purchase from? OEM or Retail? Thanks.
Looks like those two new CCB1E steppings came from monarch? Am I right?
If from Monarch, are they OEM or Retail?Quote:
Originally Posted by Repoman
