Depends on the batch and oc ability. Start at $200 and go north if its really good chip.
Quick PK1 application and first boot with new Q9650. Bios Voltage - 1.4V, Termination 1.36V. Runs super hot even under my HD-D14 with two 150cfm Deltas :eek:
Batch # L828A446 - same as andressergio and nkreshno Q9650, I believe.
http://i465.photobucket.com/albums/r...g?t=1297223928
Finally got 4.5Ghz with 8Gb of Tridents chugging away @ 1200Mhz. Can run Prime 95 blend (128k - 4048k fft) all day with 6.8Gb of ram but small fft keeps freezing up on me. Amazing chip, only need 1.4V BIOS for 4.5Ghz so far.
I am thinking I should push CCPU Clock Drive to 900mv in ACC, because currently its 800mv.
My settings:
Code:*******************************************************
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: Auto
CPU Clock Ratio ......................: 9x
CPU Frequency ........................: 4.50GHz (500x9)
************** Clock Chip Control **************
>>>>>> Standard Clock Control
CPU Host Clock Control................: Enabled
CPU Host Frequency (Mhz) .............: 500
PCI Express Frequency (Mhz) ..........: 100
C.I.A.2 ..............................: Disabled
>>>>>> Advanced Clock Control.........: [Press Enter]
CPU Clock Drive.......................: 800 mV
PCI Express Clock Drive...............: 800 mV
CPU Clock Skew (ps)...................: 0ps
MCH Clock Skew (ps)...................: 50ps
*********** DRAM Performance Control ***********
Performance Enhance...................: Turbo
(G)MCH Frequency Latch................: Auto
System Memory Multiplier .............: 2.40B
Memory Frequency (Mhz) ...............: 1200
DRAM Timing Selectable ...............: Manual
>>>>>> Standard Timing Control
CAS Latency Time......................: 5
tRCD .................................: 5
tRP...................................: 5
tRAS..................................: 15
>>>>>> Advanced Timing Control........: [Press Enter]
tRRD..................................: Auto
tWTR..................................: Auto
tWR...................................: Auto
tRFC..................................: 68
tRTP..................................: Auto
Command Rate (CMD) ...................:Auto
>>>>>> Channel A Timing Settings......: [Press Enter]
Static tRead Value....................: 8
tRD Phase0 Adjustment.................:Auto
tRD Phase1 Adjustment.................:Auto
tRD Phase2 Adjustment ................: Auto
tRD Phase3 Adjustment.................: Auto
Trd2rd(Different Rank)................: Auto
Twr2wr(Different Rank)................: Auto
Twr2rd(Different Rank)................: Auto
Trd2wr(Same/Diff Rank)................: Auto
Dimm1 Clock Skew Control (ps).........: Auto
Dimm2 Clock Skew Control (ps).........: Auto
DDR Write Training....................: Auto
>>>>>> Channel A Driving Settings.....: [Press Enter]
Driving Strength Profile..............: OC 1200
Data Driving Pull-Up Level............: Auto
Cmd Driving Pull-Up level.............: Auto
Ctrl Driving Pull-Up Level............: Auto
Clk Driving Pull-Up Level.............: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down level...........: Auto
Ctrl Driving Pull-Down Level..........: Auto
Clk Driving Pull-Down Level...........: Auto
>>>>>> Channel B Timing Settings......: [Press Enter]
tRD Phase0 Adjustment.................: Auto
tRD Phase1 Adjustment.................: Auto
>>>>>> Channel B Driving Settings.....: [Press Enter]
********* Motherboard Voltage Control *********
Voltage Types...........Normal..........Current
>>>>>> CPU
Load-Line Calibration.................: Disabled
CPU Vcore..............1.31250v.......: 1.40V
CPU Termination........1.200v.........: 1.32V
CPU PLL................1.500v.........: 1.57V
CPU Reference..........0.780v.........: 0.836
>>>>>> MCH/ICH
MCH Core...............1.100v.........: 1.440V
MCH Reference..........0.800v.........: 0.928
MCH/DRAM Ref...........0.900v.........: Normal
ICH I/O................1.500v.........: Normal
ICH Core...............1.100v.........: Normal
>>>>>> DRAM
DRAM Voltage...........1.800v.........: 2.0400V
DRAM Termination.......0.900v.........: Normal
Channel A Reference....0.900v.........: Normal
Channel B Reference....0.900v.........: Normal
You might want to raise your vtt up a notch, the 1.32 vtt setting doesnt work right its really the same voltage as the 1.30 setting.
Sorta yea, the voltages 1.30 and lower generally have a slight overvolt and 1.34+ start undervolting some. 1.30 is really like 1.31 and 1.34 is like 1.33. And as for the drive strengths I never saw them make a difference in stability so I kept them at default 800/900, unless benching.
L827a945 1.15
Nearing on total 4.5Ghz stability on air. ACC does help a little bit, at least from my experience with my older Q9650, 800 > 900mv was equivalent of bumping vcore one notch.
ACC : 900/800/0/50
Cpu Vcore : 1.3975V
Cpu Term : 1.34
PLL : 1.57
Term Ref. : 0.836
Mch Core : 1.44
Mch Ref. : 0.916
Dram Voltage : 2.06
http://i465.photobucket.com/albums/r...0Mb_Stable.jpg
That's a lovely low vcore for that speed - nice chip! You gonna bench it or at least try for higher fsb?
CPU-Z 5GHz
Cinebench R11
Q9650@4950MHz 6.04pts
http://img141.imageshack.us/img141/3838/cine550.th.jpg
Good clock oldcomer! I'm tempted to have another stab with my old Q9650 - snag is I only have the USB3P to run it on. I'm sure it'll be great for benching pi32m but don't know if this board can push as well as my UD3P rev1.6 (which now has another home). I guess trying won't harm it although it'll be on air (with lots of big fans) if I do. I think I need a pot and some LN2, but sounds too expensive for what it's worth....
Only had it for a week so far but definitely going to push it to the limit. Once I get water, say 4.8Ghz 24/7 stable :D
Got 4.5Ghz Blend stable ( 8k - 4096k fft, 6200mb). Ambient temps were a bit higher then usual because of the really warm weather here. Thanks to Jorbl3r and his Q9650 4.5Ghz settings, I was having some issue with large fft stability, plugged in his numbers for Mch Core and Mch Ref and bam..no problem.
ACC : 900/800/0/50
Cpu Vcore : 1.3975V
Cpu Term : 1.34
PLL : 1.57
Term Ref. : 0.873
Mch Core : 1.42
Mch Ref. : 0.888
Dram Voltage : 2.06
Trying to push the chip to 4.55 but I keep getting restart / freeze issues. Should I increase MCH Clock Skew to 100ps from 50ps?
Try upping the cpu skew 50ps, that was what solved that problem for me at those speeds.
L036B363 (no hits on Google!)
VID 1.2625 (CoreTemp)
Chip must have 1.31 to be P95 (small FFT) 4G stable.
Probably limited by my MB (P35)
can someone help me get my q9650 stable @ 3.8ghz??
My mobo is an asus x38 ddr3 maximus extreme! I run my cpu 24/7 @ 3.6ghz 400x9 with NB temp at 32C idle but 3.8ghz makes my NB hot reaches 50C (altough cooled with an antec spot cool)
to get the mobo stable at 3.8ghz i have to pump 1.7+volts to my NB less than that it is unstable in gaming. FSB VTT is at 1.4v, CPU PPL 1.6v, CPU core 1.3v and Loadline Calibartion enabled is a must to eliminate vdroop!!
I use the corsair h70 with push/pull stock fans to cool my cpu :) As for the TIM i use the AC MX4!
My Q9650 Retail box!
http://i54.tinypic.com/20u3ddk.jpg
My Current OC @ 3.6GHZ - 2hrs Prime95 stable, OCCT 1hr stable
http://i53.tinypic.com/fk8vtj.jpg
Your v core is way too low, and if you have the north bridge any higher than 1.58 you risk motherboard damage, your pll is not proper either I think I used 1.65 sometimes more, try also please list what timings your using on the ram, and just to be honest you should be using a q9650 on a p45 board to get its full potential out. I hope some of my input help as I've seen the worst of the batches do better than what you've provided you'll need to increase your v core to 1.42 if it works from there lower the v core by two or three intervals until it isn't stable.
so you mean i need to set vcore to 1.42 for 3.8GHZ? isn`t cpu pll 1.65v too much for 45nm cpu? as for my northbridge it needs 1.7volts less than this it is unstable! My ddr3 ram is corsair DHX 1600mhz 9-9-9-24 stock timings 1.8v
Here are my current BIOS settings on my asus maximux extreme mobo..bios is v1302
3.8GHZ 430x9 Overclock settings
CPU Ratio Setting 9
FSB Frequency 430
FSB Strap to North Bridge Auto
PCIE Frequency 100
DRAM Timing Control Manual
DRAM Frequency DDR3-1720
DRAM Command Rate 1T
CAS# Latency 7
RAS# to CAS# Delay 7
RAS# Precharge 7
RAS# Active Time 20
RAS# to RAS# Delay Auto
Row Refresh Cycle Time Auto
Write Recovery Time Auto
Read to Precharge Time Auto
Read To Write Delay(S/D) Auto
Write to Read Delay(S) Auto
Write to Read Delay(D) Auto
Read To Read Delay(S) Auto
Read To Read Delay(D) Auto
Write To Write Delay(S) Auto
Write To Write Delay(D) Auto
DRAM Static Read Control Disabled
DRAM Dynamic Write Control Disabled
Ai Clock Twister Strong
Ai Clock Skew for Channel A Auto
Ai Clock Skew for Channel B Auto
Ai Transaction Booster Enabled
Boost Level 3
CPU Voltage 1.325 Actual reading > 1.304
CPU PLL Voltage 1.6 Actual reading > 1.664
North Bridge Voltage 1.8 Actual Reading > 1.792
DRAM Voltage 2.0 Actual Reading > 2.032
FSB Termination Voltage 1.4 Actual Reading > 1.312
South Bridge Voltage 1.1 Actual Reading > 1.104
Loadline Calibration Enabled
CPU GTL Reference 0.63x
North Bridge GTL Reference 0.67x
DDR3 Channel A REF Voltage Auto
DDR3 Channel B REF Voltage Auto
DDR3 Controller REF Voltage Auto
SB 1.5 Voltage Auto
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
UPDATED!
Something you should know 2.0 vdram is considered suicide on air , secondly you should consider I have stabilized many systems and set fires to enough systems to know what's safe and what's damaging. Your northbridge/mch is too high I don't even use that much for liquid nitrogen. Secondly you must read this whole section pages 1 to the end or don't bother overlooking unless you have the money to throw around or you could damage everything you have with the voltages your using....
Wanted to add something else yorkfield based chips can die to termination being 1.38 or higher your playing in danger atm..
well 2.0v on this ram is ok according to corsair (ramguy) but 2.1v is the absolute maximum! as for my x38 chipset it is well known that it needs juice to stay stable and i saw people running this mobo on 1.7v red zone volts in the bios and according to intel spec this chipset temp limit is 90C and i never reached that much temp. the most i reach is 50c (cooled with antec spot cool) with with 1.7v when you say you dont even use that much voltage for LN i dont beleive you sorry remember x38 get hot soon and needs volts at high fsb :)
You could very well be right since its x38 and all of us with q9650 or the extreme version used p45 ud3p motherboards to achieve great clocks. But honestly you really should go to p 45 if your having trouble with 425 fsb or greater . My qx9650 which I sold for its full retail cost because of what it could do, used ud3p mobo and could do 530 fsb with low termination and low volts ran very cool :) maybe you should consider it.
