thanks. I also have vintage version for that pic in flickr :)
http://static2.nagi.ee/i/p/413/78/103446839463d8_o.jpg
Found that one, was taken long time ago.
That is not underwater :)
http://i970.photobucket.com/albums/a...g?t=1269524928
Canon EOS DIGITAL REBEL XTi
f/4.5
1/13s
iso-200
28mm
Beautiful Ridney.
Nice shot Don and Ridney
Great work Weevil and Soul
http://farm5.static.flickr.com/4045/...9d1e4daa_b.jpg
Camera: Nikon D40
Exposure: 30
Aperture: f/4.8
Focal Length: 32 mm
ISO Speed: 200
Exposure Bias: -2/3 EV
Flash: No Flash
Kit lens
http://farm3.static.flickr.com/2732/...6cfb7a4c_b.jpg
The main part of this shot is the snow part leading up though the forest with Mount Blanc in the Background. The forest is a hidden Gem in Les Houches with view of Mont Blanc and clear walking paths which turn into the town cross country circuit during the winter months. The forest boasts many great features from small streams running down rocks, to vast ice walls which locals practise they ice climbing.
1024 x 683 | Orignal Download | PhotoStream | Image Licence
You can use the image and edit, but full credit to myself Bentleya and a link to my photostream must be present if posting somewhere else. Please see Image Licence
I never saw the chair, the water hose or the ball while I framed this shot.
http://farm5.static.flickr.com/4044/...f168767b_o.jpg
ANP what's your standard procedure for setting up and taking those beautiful lighting shots you always have?
i used to think that getting a shot like that required some sort of magic external device hooked to the remote control port so that when the lighting flashed it snapped a shot... but i have never found such a device although i bet one is out there.
how do you do it?
Lestat, you use a longer shutter time, such as 10-20 seconds, in combination with an ISO and aperture that will get you the correct exposure for the rest of the shot. You should get a remote so you can hold the shutter down and release it yourself though, this way you have complete control. Release right after the lightning strikes so that the sensor doesn't start exposing the dark night sky on top of the lightning you just caught.
what find of an fstop would you use?
and am i right in what i said that there are photo sensors (light sensors) that open the shutter for light flashes?
something like having a camera sit somewhere and it goes off when a flash is fired, but this case is the lighting flash?
There may be, but I've never heard of it. It doesn't sound very practical though.
Looking back, I have used f/4 and ISO 100, but this would be equal to f/8 and ISO 200 which is probably better due to a wider depth of field. 10 seconds at a time is all I'd recommend, but you can experiment. This all depends on your lighting conditions.
cool man thanks for the tips
maybe when canon sends my 7D back,, AGAIN... this time it will be working and i can actually use it
Lestat, I used 30secs shutter and a f4, the higher you go on fstop, the more dark the sky gets, I have used f8, but got a black sky and a thinner lightning strike, so I figured out f4 - f5.6 is the best bet depending upon how often the lightning is falling, shooting RAW is very important here, cause sometimes there is a huge lightning and it blows everything in my frame, but RAW processing saves me and I am able to recover some details in the over exposed part.
New Spring:
http://farm5.static.flickr.com/4009/...d2d678b4_b.jpg
Canon EOS DIGITAL REBEL XSi
Aperture: f/4.5
Exposure: 0
Flash: No
Focal Length: 105 mm
ISO Speed: 100
Shutter Speed: 1/1000 second
Me in Boston:
http://farm5.static.flickr.com/4052/...a6c732c8_b.jpg
EXIF
wow, now i know why people such a great amount for that lens, crazy DOF!
Yeah, I absolutely love this lens. So far I find this has the best focus ring for an AF lens and the lens is really sharp wide open (I also have a Nikkor 50mm f/1.2 and Olympus 50mm f/1.2, both don't come close in sharpness). Also having weather sealing is a nice touch, got caught in the rain a few times and didn't have to worry about my camera getting ruined.
http://i970.photobucket.com/albums/a...g?t=1269607929
f/5.6
1/60s
iso-400
85mm
