USB device not recognized
I'm having a problem with my front USB ports using the 5/6 and 7/8 connectors on the P5B Deluxe wifi board. When I connect any USB device into the front USB ports, I get the error that Windows XP does not recognize the device. I know power is being delivered thru the port because the light on my USB jump drive is lit. I've disabled the USB wifi port (9/10). The case I'm using is Lian Li PC-60Bplus. It has a mic jack (works fine), headphone jack (works fine), 2 usb ports and the IEEE port(haven't used it). The back USB ports work fine and detect everything. I'm also using a logitech bluetooth keyboard and mouse that uses a bluetooth hub via the back USB port.
I've tried uninstalling all the devices under the USB controllers in safe mode and have Windows XP reinstall the drivers, but that didn't work. I even reformatted my drive and did a clean Windows XP install, but still get the problem. I did install the front USB ports incorrectly the first time, but will that render the connectors useless? Everything else on the board seems to work fine. I haven't overclocked the system either. Any help will be appreciated. Thanks.
Finally Building My First Extreme System..but..
Processor: Intel E6700
Bios Revision: ?
Memory: 2x Corsair XMS2-6400 DDR2-800 1gb w/heatspreader
PS: Thermaltake 750W
HDD: 5x Maxtor 500gb Sata II/300
Graphics Card: PCI Express ASUS EN7600GT Silent DDR3 256mb Dual DVI
Processor Cooler: Asetek VapoChill - Ultra Low Noise
Aero Cool case
Configured Voltages: ?
Configured FSB: ?
Configured Ratio: ?
Configured Memory Timings: ?
Any other applicable configuration modifications:
I have installed the motherboard, processor, cooler, graphics card, power supply and power cables to 5 Sata drives. I plan on using raid 5 and at this point I wish to ask what is the sequence of connections to the mobo. I will be using windows XP Pro for my operating system. This is my first system and want to start with the initial/basic installation & configuration and than build my knowledge for oc'ing. Many thanks in advance to Xtreme Systems for being here and all who support it.
