Stuck, what to try next ?
I have a wk 24a e6600 and right now I can't to overclock to 4.0G
Settings are:
FSB: 439
Memory Voltage: 2.25V
CPU Vcore Voltage: 1.65V (appears to be 1.62 actual)
FSB Termination: 1.5v
MCH Chipset Voltage: 1.65
ICH Chipset Voltage: 1.2
Memory using SPD
DRAM ECC Mode: Disabled
Hyper Path 3: Disabled
DRAM Throttling Threshold: Disabled
Advanced CPU settings:
Modify Ratio Support: Disabled
Microcode Updation: Enabled
Max CPUID Value Limit: Disabled
Execute Disable Function: Disabled
Enhanced C1 Control: Disabled
CPU Internal Thermal Control: Disabled
Virtualization Technology: Disabled
Intel (R) SpeedStep (tm) tech: Disabled
I have Corsair XMS2 CAS4 6400 memory (2x512MB)
At FSB of 439 it will boot, but Windows doesn't start. So any ideas on what I can do to get Windows loaded ? If set FSB to be 412 at the same setting as above the Windows will start. Have I found the limit of my CPU ?
If I set FSB to be 440 it won't boot. Is my memory holding me back ?
Is my Board Dying? or CPU?
First I must say that this is my first system build and first OC. I knew this was a possibility but didn't think it would happen this soon. Lately my OC has been showing signs of being unstable. I've heard that an OC'd system will need to be pulled back eventually because of the voltage and electrical things that happen which I don't quite understand.
My rig has been OC'd to 340fsb since September and gets a lot of use. I've had to take my system from 340x10 fsb at 1.4vfsb, 1.65vmch and 1.525vcore (1.5v actual) to 333x10 with the same voltage. I think it's stable now but I won't know until Prime runs for a while more.
Is this the beginning of the end for my system? Is the CPU or the mobo causing the problem?
Thanks for the help, I just want to know what to expect and what I can do now?
