My new P180 setup, my very first WC job. Needed internal, wanted quiet and clean.
Pics:
Overall. Added a bunch of additional noise dampening foam to the interior of the P180:
http://img253.imageshack.us/img253/2...overallpf2.jpg
Side. The "extra" smart coils you may notice if you look carefully.....are not part of the loop.....they're used to disguise the USB cables and maintain a consistent aesthetic LOL. And no, the CPU > Rad hose is not kinked....it's just the angle of the pic. Next pic shows a smooth bend.
http://img261.imageshack.us/img261/2252/h2osidemh3.jpg
Upper chamber. Noctuas, more noise dampening, cable management.
http://img255.imageshack.us/img255/8760/h2ouppertr7.jpg
Lower chamber. Tight fit but works alright I think. High output fan is connected to fan controller.
http://img253.imageshack.us/img253/124/h2olowerco0.jpg
Front. Added 2 intake fans, 1 each for upper and lower chamber to increase airflow to the rads. Very minor modification.....some rubber grommet for clearances, some noise matting for separation.
http://img253.imageshack.us/img253/2156/h2ofrontug1.jpg
