Opteron 148 [540] @ 3,160 ghz vcore 1.5
Watercooled.
http://student.umb.no/~astorp/Images...gz%20prime.JPG
http://student.umb.no/~astorp/Images/superpi26_CPUZ.JPG
Watercooled.
Are you running your 148 on a Asus A8N Sli Premium?Quote:
Originally Posted by Nightprowler_77
jupp, runs like a dream
With your clocks do you increase:Quote:
Chipset voltage : 1.5 > 1.6
HT voltage : 1.2 > 1.25
No, havent done that.
Was curious, as it doesnt seem to improve the O/C for me when i increase those settings...wanted to know if it makes a difference for you.Quote:
But still playing with it :p:
Cant wait to try this chip with water...
Also ive noticed that in your 2nd rig you are using OCZ 4000 EBs, have you tried running them in your AMD rig? I planning to get them, wanted to know how they perform with this board!
The BallistX har better, but for some reason I cant run then with a divider, so right now the OCZ are in my AMD rig, maxing out at 260 HTT.
Timings, vdimm and what multi are you using?Quote:
Hi All!
I tried OCCT and still passes, this program is really memory picky. :slobber:
http://www.xs4all.nl/~famchow/A64_Op...OCCT_1.48v.PNG
I have tried 3100Mhz 1.6v, is 32M stable but not prime/OCCT. It seems 3GHz is the sweet point. Still nice :D
This is really nice for a CAB2E core :toast:
Nice chip kakaroto :clap:Quote:
Originally Posted by kakaroto
This is on Air or...?
This is on WC and IHS still on. Case closed and window closed :DQuote:
Originally Posted by [ r2 ]
With 5C outside I hit 26C idle and 37C stress :toast:
Pretty cold outside :p:Quote:
Summer is approaching here in Aus, dont think its going to be easy to O/C this chips even with water :rolleyes:
What did you manage with your 146 on stock vcore?
On 1.36v (1.4v) i could manage 2.9Ghz prime stable. I have no screen of it, but it ran one hour SP2004 then i quit and jump to 3Ghz.Quote:
sweet :toast: CAB2E 0540FPMW :toast:Quote:
http://slike.slo-tech.com/16147.jpg
:banana: :banana:
Told you how hard OCCT is on your RAM/CPU!Quote:
Nice results mate, you seem to get the same temps in a 5C ambient as i get in a 20C ambient.
Good to see the extra dual rad helped a ton. :up:
3,1GHz is close to the max of my CPU for OCCT, not sure wheter the RAM or CPU is maxed out.
http://img.photobucket.com/albums/v6...CT3100MHz1.jpg
CABYE 0540 FPMW
3.0GHz @ 1.425v (in BIOS) OCCT stable on air.
http://img265.imageshack.us/img265/2...pass8yw.th.jpg
my new opteron 144.. CABNE 0540 BPMW
http://mitglied.lycos.de/meinnamegeh...primelarge.JPG
tested on abit an8 ultra with aircooling.
My dual-core Opti will be here tomorrow so I kicked the CABYE out and gave my CABNE another last spin.
Looks like this one is solid in the 3 GHz club. :toast: CABNE 148 0528GPMW.
This is 3000 MHz at 1.55 V, prime95 running for 24 hours at the time of this shot. Air cooling, Big Typhoon, SLI-DR, Geil One TCCD.
http://www.cons.org/cracauer/miss-cabne.png
http://www.cons.org/cracauer/oc-scre...5-prime24h.png
what problems are you getting with ballistix/opteron and divider?Quote:
boot problems or just under stress/load kinda problems
Zeus nice overclock but i was wondering what your watersetup looks like (components). Since you got great temps under 3ghz load.Quote:
Originally Posted by Zeus
Just received a Opteron 148 CABYE 0543 retail from Newegg tonight.
So far seems like a pretty good chip. I'll let it burn in a few days at 3GHz and try for more later.
Current OC 3000MHz, 300x10, 1.5v 100% stable
Max OC 3080MHz, 280x11, 1.6v, not 100% stable but 1M SuperPi of 27sec on loose timings
CPU Temps 100% load @ 3GHz 1.5v 40C, idle 29C watercooled ThermalTake Tai-Chi Case
TCaseMax 65C
TDP 67.6 Watts
I just got a 148 from NE last night. It was a 0540FPBW :woot: It's got a great memory controller. Memory isn't tweaked, just wanted to run the high HTT.Quote:
Originally Posted by D4nnyOcean
http://img427.imageshack.us/img427/2...05401gt.th.jpg
This is on a TT BT.
dogsx2, your always getting some of the sweetest cpu's. NE's out tonight. Is that on a 150 divider? My 146 is considerably slower with that one but works very well with 166. My highest HTT is below @166. Mem was 271, screen froze though after pi - (cold). Voltage is not as shown, actual is 1.61. [IMG]http://img345.imageshack.us/img345/4...04719th.th.jpg[/IMG]
Originally Posted by coop
pretty good clocks there coop. I didn't read the 1.61 until after I looked at your ss. I thought WOW, that's the lowest volt for that MHz I've seen.LOL
It was with a 133 divider. The ram was 4000VX and I didn't want to change the jumper.
