Just flashed my Maximus Formula from BIOS 1004 to the Rampage Formula 0219. No problems to report, flash went fine just like any other flash.
Thanks to all the guys who helped track down that ES of AFUDOS.
Was a name ever decided on?
I JUST RAMPAGED !!!
so far so good.
Is anyone aware that one of Asus's ftp is still unlocked?
This one works fine ftp://ftp.asus.com/
Is the SE version of the MF required for this mod? Thanks.
no, both Maximus boards and a few P5's will flash
finally got a stable board, had to rma first one, now i,m looking to o/c. any one have a good stable set up for a 3GHz o/c. this will be my first attempt at o/cing, so not really sure where to start.
i'm running a Q6600 G0, with mushkin 996587 pc6400 ram @ 5 4 4 12, air cooled.
I saw the P5E, but I noticed there are two different versions of the MF. Does the SE have something the RTM MF does not? And by your response, I'm making the assumption the RTM works just the same.
EDIT
Appears the only difference b/w SE & RTM is compatibility with ECC/unbuffered DIMMS. Joining the club.:up:
No, the SE has a waterblock for the NB. Read more here:
http://www.xtremesystems.org/forums/...d.php?t=168119
Is anybody running 4x1GB RAM?
I ran into an issue with the newer bioses (MF1004 and RF0219). I need a ton of NB voltage to get it to POST and boot Windows, around 1.72V, with all the timings and other settings on auto. If I try to change any timings, then it stops posting again, so I'd assume it needs even more voltage on the NB.
Going back to the MF0907 BIOS solves it, and I can boot fine with all auto settings. However, I have a X3350 coming this week, so I need a newer BIOS which has proper support of the CPU.
Any ideas?
Wow!! What a weekend!! Kids on TILT, Visiting Outlaws that don't know when it is time to go home, bathtub hot water tap falling off, I finally got to do some playing with the rig in the wee hours of this morning only to lose an hour to Daylight Saving Time!!! :eek: Anyway here is where I am now, any suggestions, tips, volts, etc. would be greatly appreciated. I managed to do a quick 1 Hr. OCCT and was stable.
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 10
FSB Frequency : 400
FSB Strap to North Bridge : Auto
PCI-E Frequency: 110
DRAM Frequency: DDR2-1203
DRAM Command Rate : 2N
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 45
Write Recovery Time : 5
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Ai Clock Twister : Strong
Transaction Booster : Manual
CPU Voltage : 1.40625
CPU PLL Voltage : 1.56
North Bridge Voltage : 1.55
DRAM Voltage : 2.22
FSB Termination Voltage : 1.4
South Bridge Voltage : 1.125
CPU GTL Reference : .63X
North Bridge GTL Reference : .67X
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : 1.55
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Disabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Auto
Performance Level 5, all Pull-ins Disabled
new 24/7 settings
http://i237.photobucket.com/albums/f...table_4400.jpg
Still no joy even with all the leads out and just using the boards power buttons. I guess im gonna try a new psu as it seems to work after i pull the lead out of it then put it back as if its reset something in the psu. And does anybody know if i could get a refund for my formula from ocuk as i have only had it for 5 days and i may as well just get a rampage or will they make me take another formula.
Cheers Paul
this is the best bios I've tried so far
I managed to reach 4ghz!
http://img142.imageshack.us/img142/1...stscoretz2.jpg
just a quick try with 515fsb - PL7...
seems that with RF bios my mem is up a bit...about 20mhz..
