Don’t take some of those settings literally.Quote:
Originally Posted by MARINECOP
That’s a guide to get you started.
For a beginner you have to input lower settings at first
Then work your way up to your highest stable settings.
Use these settings to get you started.
CPU Frequency = 333
Dram 667
PCI Exp 105
PCI clock 33.33
CPU Vcore 1.4
Memory voltage 2.05
FSB Term 1.4
NB Vcore 1.45
SB Auto
ICH Auto
CPU multiplier 9X
Memory latency 4-4-4-12
In CPU settings enable execution disable bit the rest disable
Take your time and raise the FSB until your no longer stable then make your adjustments.
If you have already run this rig at 533 X 7 then I would say you have a nice CPU there and if you start low at 9 X multiplier you’ll end up with some pretty nice clocks at lower Vcore.
Also your limiting your rams bandwidth and Frequency at 533 7 X .
Your ram should be able to hit DDR 1000 at 5-5-5-15 @ 2.1 volts DDR 800 for sure.
Like I said take your time and use the recourses on this site but don’t get discouraged if you can’t run the same as others (you have to find your own sweet spot)
:cool:
