uhm, forgot about those damn coldbugs ^^Quote:
I have a new OC with my 3700 + Sandy to 3000Mhz in the superPI 1M obtaining 28.454 seconds and a refrigeration for air with a XP-90c whit the stepp KAB3E 0548:
http://img88.imageshack.us/img88/121...hz300x1.th.jpg
I believe that it is a good score bearing in mind that takes refrigeration for air....
goodBye!
Wenn you could adjust the ramtimings a little tighter, you could get a better score. Try cas2.5-4-3-6;)Quote:
Originally Posted by Jackarturo
Ohh thanks, Or, that putting these latencies, get better times, or major stability?Quote:
Originally Posted by BvK
Anyhow, it he will try it, thank you very much.
Goodbye
Another question ... this stepping:
KAB3E 0548CPMW
1376599k50191
would be of the same thing raises more or less that that of the author of the post, truth?
It He is that I have this stepp ;)
Goodbye!
You get a better time in Superpi, but most likely the stability will suffer.Quote:
What a great chip. Nice temps too :)Quote:
Originally Posted by -De$troyeR-
What kind of watercooling do you use?
Monge :toast:
thx.... :cool:
it's a normal watercooling, nothing special.....
room temp ~24°C :)
http://www.xtremesystems.org/forums/...&postcount=527
THX, a very nice setup :)Quote:
A twin Mora 2?
And which Cpu head is that?
Monge :toast:
no a mora 2 pro + fan-adapter
http://212.227.231.249/watercool/cms...pics/20310.jpg
http://212.227.231.249/watercool/cms...pics/20570.jpg
the cpu heat is called nexxxos xp bold.
THX a lot :)Quote:
How many fans on radi and where's the pump?
Cobber tubes going from reservoir to Mora?
Cheers Monge :toast:
4 silent fans @ 12v :)Quote:
Originally Posted by Monge
in the front between hdd's and fan-controllerQuote:
http://people.freenet.de/destro/Wak%...r/DSCF2395.jpg
yes, exactlyQuote:
http://people.freenet.de/destro/Wak%...r/DSCF2170.jpg
cheers ^^ :toast:Quote:
De$troyeR: THX for the pics :)
Very nice work/setup.
Cheers Monge
yes nice look,
man these 3700s are owning :P
you're welcome :)
thx :DQuote:
Originally Posted by Philosophy
best 3700 i've seen was:
3200@ 1,40V
3321@ 1,53V
3436@ 1.61V
in germany
greetz
It`s Stonkas 0547GPMW Joker.
jepp ;) hast recht :P
ImpressiveQuote:
Originally Posted by tHe_jOkeR
Air ? step please :)
watercooled. stepping : 0547GPMW batch 151 ;)Quote:
Originally Posted by boblemagnifique
People I just mounted the ZalMan 9500 LED on my 3700+ but :banana::banana::banana::banana: it quite suck...
@ 2950 Mhz with ~1,45V I get 59°C full load (on my MSI Neo2 Platinum)... what the hell?!?!
Get the TT BT with a stong fan...the best aircooling in my opinion;) But 59 load is to much for a Zalman 9500. Then the box cooler would be better:eek:Quote:
Originally Posted by Punisher!
With the BOXED I had ~65°C in the same conditions.Quote:
Do you have TT BT? I can't get my GPMW stable @ 3Ghz with these temps... a friend of mine has bought the next KAB3E 0547GPMW identical to mine (except for the last number of the serial of course... his is 216, mine 215) and he has it 3 Ghz prime stable with 1,376V (watercooled).Quote:
Mine should do at least 3Ghz air :(.
Why these :banana::banana::banana::banana:ing temps? I had put even the arctic silver 5...
one of my CABQE 0547GPMWs will do 3 Ghz with 1.36 volts on air ;)
room temp has to be a couple degrees below normal tho.
otherwise does 2.99, wants more volts for 3
