Hey Onepagebook look here http://www.google.co.uk/search?hl=en...e+Search&meta=
Your famous, top of the google search for land of Buckeye!!!!
Very sorry to hear of your bad luck I wish for better things for you, keep your spirits high.
HOLY CRAP I JUST CRACKED UP TO THAT IN MY OFFICE AT WORK!Quote:
Originally Posted by Stumpjumper5200
:D :D :D
HeHe yes I find it funny too, and true, though theres a tosser called chainbolt (intel pimp) @ OCAU who would delete your post for saying that :slapass:Quote:
Originally Posted by g0dM@n
Your gonna have to try out your hardware to see what overclocks you get, no one can tell you this. You could try settings you see around, but it doesn't guarentee they will work for your stuff. read this post, OPB posted his results with a dual opteron cpu and some micron 2 x 1gb's, which should be the same as ballistix.Quote:
Originally Posted by joe.latino
opb .. sorry to hear about all that has happen .. but glad ur back up and running .. thanks for all the testing ur doing ..
im about to give up on the expert board .. it just seems no matter what drive strength or whatever .. i just keep failing mem test no matter what .. stock is fine with all the auto settings .. but anything other then that and test 5 or 8 kills it
i know my ram can do at least 260-270 as it did on the sli-dr :stick:
Have you tried 2T (clock command disable)? I'm just curious.Quote:
Originally Posted by jetjaguar
I only got my board and cpu the other day, so i still plan on playing with stuff before i give up and start rma'ing things.
So far I can do 261 2-2-2-5 1T with auto drive/data @3.4 something volts can't remember right now but I'll report once I get home. I am sure I can do more I am just easing my way in to this board.
not on this board .. my sli-dr ran at 1t .. 2x1gb sticks .. in orange slotsQuote:
Originally Posted by Diverge
OPB, u live in columbus? SO do I!!
OPB, can you ask Oscar which older NF4 SLI-DR bios that the new FX60test.bin bios is based on please? thanks . .
AFAIK, although it's on DFI's site, that particular bios isn't one of Oskar's....Quote:
Originally Posted by xgman
Originally Posted by s7e9h3n
well that would make me nervous right there. . . lol
Have you try clean install windows?
memtest is NOT the Bibble of RAM stability.
Windows mode bench marks are. especially Prime 95 , super pi mod 1.4, and don't forget the most important windows version of memtest.
rev02 reallyQuote:
Originally Posted by Mike6969
Originally Posted by Onepagebook
yes im on a clean install of windows .. im running super pi 32m stable right now at 12x245 = 2948 @ 1.59-1.6 which is pretty high .. temps at load are 35c .. but my pwmic is hitting 55c .. my case has no airflow though .. just the side panel is off
i havent tried prime yet .. windows version of memtest ?? all i hear people say memtest .. not windows memtest
any hints on some drive strgnth .. etc for crucial ballistix ?
can you check your voltage on the old DR board and the expert........i still think the other one was overvolting badlyQuote:
your load temps are amazing............how in world are you getting them so low
Ditto - I know the expert reads temps a little lower (~4-5C) than the old nf4 boards, but 35C loaded on an Opty150 @ 1.6? You sure your're not stating the idle temps as I see you're using air-cooling?Quote:
Originally Posted by dinos22
true about the lower temps shown on expert.....few users over at OCAU are reporting pretty low temps....only way to explain is the temp controller is not picking up the true temps.........but that's extreme.......i guess it's bloody cold where he lives.....north pole anyone heheheheh (last time i said this i was greated by Sydney overclocker with IHS off heheheheh)Quote:
my load temps were really low with my opty 146 too, and i have 1.66V (2,9GHZ on air) through it, with a load of 46°C.
My opty 170 is running pretty damn cool too, only hit around 42°C on load (dual prime small fft's), with around 1.58V @ 2.7hhz.
....wow so cool that it doesn't even register lol......Quote:
i was editing it, since i forgot the numbers and wanted to see my sig via the quick post :p:Quote:
not so stable
anyways my scythe ninja cools extremely well .. my cpu idles around 22-26c .. depends .. and loads anywhere from 35-36c when its nice and cool in my room and like 39c when its warm
its my pwmic temps that are like 54c ..
on my sli-dr my winnie at 1.6vcore @ 2.6 idled at 29c and loaded around 36-37c ..
when i had my xp120 which made horrible contact .. it idled at 38c and loaded into the 50c and that was at 2.5 ..
i wasnt able to overclock higher until i switched to the ninja
Hehehe...that's what I thought... :toast: But your temps are reasonable. 35C load is quite a claim on a cpu which some people have problems even getting stable on water ;) ......Quote:
Not saying that I don't believe you (OK well maybe I am :p: ) - but do you have any screenies of your cpu @ those temps?Quote:
+ separate temp sensor measuring air temps in the areaQuote:
