That's the reason why I am quite sure that removing the HS will result in much better OC.Quote:
Originally Posted by p0tempkin
Removing HS won't give any advantages and only slightly lower temperatures at low clocks with low volts. But the higher voltage and clock goes, the higher the heat output of the core and the higher the isolating effect of the heatspreader.
Got a 3700+ Sandy running very nice at low voltages until 2700 MHz. However, 2800 MHz needed 1.64V and temperatures were very high (~50°C). Cutting the HS off resulted in 2800 MHz @ 1.53V rockstable and only 38°C load. Maxed out without HS at 2950 MHz @ 1.66V. However, I have to admit that this one had a really worse mounted HS.
Anyway, X2's naturally generate more heat than single-cores so that's why they need better cooling. And removing HS will give massive improvement, I think.
