indeed..I'm curious with how much vcore prime runs @ 3.0GHz. Could you test that?
@funkflix, thanks trying to get some like yours or Stonka's.
@BvK, I will, getting ready to go run atm. From my messing with this yesterday, I think these like to do prime. For use with air or water these are very well suited.
Priming now, 3003@1.39v. I'm only going to do a couple hrs. I have more to try out.
2-3Hours are enough to show us that the Chip is stable for the first.
OK, done. Load temps were 38c-39c. I can post a thumb.
http://img331.imageshack.us/img331/7...meb139v6di.jpg
This is mine for the moment:
KAB3E 0547GPMW liquid cooled whit his.
http://img56.imageshack.us/img56/234...temp3ve.th.jpg
http://img81.imageshack.us/img81/633...31009ki.th.jpg
This one takes 1.424v for 3Ghz. http://img153.imageshack.us/img153/2...424v4cd.th.jpg But still will do 32m @ 3063 like other one. http://img80.imageshack.us/img80/328...424v9ei.th.jpg
Come on coop, give it some volts
I was able to do a 32m@3203 1.55v with this one too. This seems to be not so easy. If someone would like to verify this please do and post. I was using 1.450vx110% to get the resulting 1.55v in Windows. I think it would be a challenge to say the least on air. I am curious though.
http://img143.imageshack.us/img143/8...203155v3le.jpg
You beat me here b4 I got my post up.
Haha coop, that's pretty good, but CPU idling at 20c? You've got some low ambients! My opty 148 on watercooling and relatively low ambients was idling at 25c with 1.6 volts lol.
Well, my res is a Coleman cooler, and sometimes I take gal. milk jugs, that have been filled w/water and frozen, and drop them inside.:D
lol coop
MORE VOLTS! Give it 1.63 and see if you can do more
my 148 @ 3ghz idles @ 22c w/ Tt Typhoon. 1.5v
uhh well i guess you have 15c ambient and IHS removed ;)
I was looking for something a bit higher but what it is is what it is.
http://img157.imageshack.us/img157/2...twk164v5te.jpg
Thumb shows 1.63v ? http://img157.imageshack.us/img157/2...164v9ft.th.jpg
Beautiful coop! I don't think you'll go much further now unless you were to pop IHS.
uhh..no. ihs was removed and then replaced. 17c ambient. not bad tho!;)Quote:
I put a h2o cooler on my vc and it is in the same loop. It added about 6-8c and makes a little difference. The time is not so good, I'm just glad to have made it through.
Air cooling has come a long ways. When I got mine the best was a slk900? Still using in this box. But the temps have really come down since then.
I just don't see how you could have a CPU idling 5c above ambient with 1.5 volts on air with the IHS on.Quote:
Originally Posted by cadaveca
With 1.5 volts and my air cooling i idle about 13c above ambient on my 146.
Here's one of my best idle shots
http://img.photobucket.com/albums/v7...g/753e41d3.jpg
That's 23c idle with 1.6 volts, but that's in 16c ambient, with a naked CPU, and my damn good watercooling setup (lapped G4, D5, 120.2 weaponcore). 7c over ambient, even though the volts is .1 more here, i dont see how you can get 5c over ambient with air cooling.
I won't argue though.
ok, so is there a way to tell which of these are the new E6...CFBOX steppings? for the 3700+ i mean
my 0547GPMW 0001 on air
http://i6.photobucket.com/albums/y23...erpi32Mop3.jpg
Thought that I also had an 3.25GHz screen with superpi 32M...but can't find it anymore.
Hi all, i am new to overcloking, but i have managed to get the following results with my san diego and a big typhoon
but i dont get why i get so bad scoring in super pi any ideas what will improve it?
http://img202.imageshack.us/img202/3183/over3ec.jpg
So, little update from my side.
Cooled with modded vapo :D maybe i can hit 265HTT 1:1
cu
@Sauron Vie, you make that look so easy. You should be able to get 265 with those xms.
@BvK, that is a fine chip. I tried to get a 3100 prime with 1.488v but only 3080. Oh yea, 0001 is pretty cool too.
**EDIT** It looks as though 32m @ 3200 1.55v is not so easy. ***
