Hi im a bit of a newbie to this Pentium M overclocking, I managed to get hold of
Pentium M 755 for £70 new (Ebay can be good some times :) ! )
Asus P4P800se for £45 almost new
Asus CT-479 for £30 new
I know the 755 is only 400Mhz Fsb but as it has a 20x multiplyier (i think) i have high hopes - now i have some questions (apologies if there dumb ones)
1. Whats the best memory for this system, can I go for 2 gigs of bog standard PC3200 or do I need some better memory - OCZ, Corsair etc at Higher raitings - Im confused about all there memory bus to Processor bus speeds it seems like most people have the memory bus at greater then the Processor Bus surely this makes it no faster ?
2. It seems that 400mhz Dothans dont overclock so good, what do you think i can expect as my maximum stable overclock - basicaly what should i aim for, I also found that there is a way to convert a 400Mhz dothan to a 533Mhz dothan by grounding the bsel0 pin apparently (http://www.hardforum.com/showthread.php?t=888963) unfortunatley the database seems to be down :(
Sorry again for the newbie questions ;)
Thanks in advance for any input!
Stu
