turn to the 1st page la :confused:Quote:
Does that mean that a DFI Infinity nForce 2 also works with the booster? Or do I have to mod the board/booster?Quote:
DFI
DFI nForce2 Lan Party Rev. A
Abit NF8 WILL NOT FIT. Picked one up at CompUSA- first slot has a cap too close to the DIMM, second slot means that the Booster is blocking the first. Board went back same day.
Didn't trying bending anything, didn't want to risk the board or Booster.
Damn you Abit, why couldn't you be normal and put in three slots?!?! *Shakes fist angrily*
turn to first page??? what do u mean?Quote:
Originally Posted by pyridoxine
It coould mean that only the Rev A not the Rev B. I got the rev B, though.Quote:
Originally Posted by Vassili
And does the booster work?Quote:
Originally Posted by FLDQUY157
please add DFI nf4 all models to the list
thanks
and 3.8v for the DFI :)
Yup, the DFI NF4 was fully tested by myself and added to the OCZ Compatabilty list with full notes for operation:Quote:
Originally Posted by stealth17
http://www.ocztechnology.com/display...ocompatibility
Does the DDR booster keep our ram safe at night against the even the toughest of foes(the 5v rail on the dfi nf4's?)
I'm reading about compatibility with DFI NF4. I have a PowerStream 520W (old ones, not like the last revision) and this PSU have a unique 24 pins connector, is there any way to connect it? any adapter :D?
will it go above 3.8v?Quote:
Originally Posted by andyOCZ
It should, yes. Why you would need that I dunno. :slapass:Quote:
does the booster work with the Gigabyte K8NXP-9?
greetz
XtremeSystems man! :woot: :banana:
Almost forgot where I was posting! ;)Quote:
:slapass:
does it work on the Epox EP-9NPA+ SLI ?
NO, it doesn't :)
glad that Epox support is up to date...
this is the most up to date list, as of July Second 2005, from the feedback posted here in this post.
MSI
k8n neo platinum.
K8N Neo2 Platinum
Epox
8RDA
8RDA ver. 1.1
8RDA3+
Abit.
Abit NF7-s rev2
AN7
IS7-e
IC7-G (worked for some, but not for me)
Av8
AS8
Gigabyte.
K8NS pro
K8NSXP-939
K8N nonPRO
K8NSNXP
k8Ns Ultra 939
GA-K8NF-9
Asus.
P4C800-E
A7V880
P4C800 Deluxe
Asus P4P800-E
P4P800SE
k8n-e
SK8V
A8V
DFI
DFI NF3 Ultra 250 GB.
DFI nf4 all models
Random.
Soltek qubic 3801
Chaintech VNF3-250
Chaintech VNF4 Ultra
shuttle an51r
any idea about the abit an8?
it wount work :(Quote:
Originally Posted by babyelf
hmm ok.. =/
u tired it before?
opps sorry i was thinking you said a8n...not sure about the an8Quote:
too many wierd number and letter codes. should stick to lan party or something easy to rememeber :p:
Andy, or anyone else for that matter. What about a MSI K7D-Master running 2 1800+ @ 2400MHZ each and 2 gigs of Kingston non registered ram. That leaves 2 slots open.
Any word about it for the Asus P4S800?
