Well, I removed my IHS and cranked up the rails a bit on my PowerStream 520W. We'll see if she Primes any higher.
Spoken like a true overclocker. :D
no updates about this mobo??
Yeah, it's being sold as soon as the DFI is available.
i tried running the agp at 75 mhz and it seems to have fixed a lot of my stability problems... :)
I finally just got my replacement from newegg.com.
I cant wait to finally try out the OCZ 3700EB ram since the board took a crap basicly right away when i tried before heh.
hi guys!
i got i problem my magic bios tool didnt work correctly so i cant load the latest bios version...
can someone uf ya folks give me a link to the latest or plz. mail it to: nazir@networld.at
thx
seEn andL
so.... nobody who clould help me?
well i got the 07-09 bios now but i got the core bug and its no matter what vdimm i set because it does everytime 2,67 Volt :banana: :banana: :banana: :banana:ty crap i got bh-6 now and i cant get higher!!! i nedd vmod or ddr booster!
i removed my IHS too but i got a bad paste and so first i got worse temps than with lol so i did much more on the core and i got now on load in games like doom3 49-50 degrees...
but i only got 2 single fully-cu raddis and cape kc-42....
my cpu did before 2250 max stable and it does it now...
everytime i get over 2250 it becomes instable and end s with bluescreen...if i set vcore to 1,8 under load its the same!
i ll sell my amd64 3200+ 1024kB c0 stepping and get a pretested cpu!
seEn andL
where could i get a pretested CPU... my chip sux 2 much. somewhere that would ship to all of europe preferably
cheers
I've never heard of a site to buy pre oc'd cpu's. Your best bet would be to buy them from a forum and find out how high they oc.
how do you get clockgen to go over 1.55?Quote:
Originally posted by Jeff
He's probably just trying to cover Epox's butt. ;)
You can also uncover the 1.8v option by screwing with ClockGen.
hi
i dont know if evo sells everywhere to europe but just ask him it doesnt cost anything!
check out http://www.xtremesystems.at/index.php
:P
seEn andL
dont understand german... does the site exists in english? besides, i wanted a place where they pre-test the CPU... dont u know anything like that?
cheers
oh sorry yes i understand i only know this site
but there u can get pe tested amd64 i know i m sure!!!
maybe i cans ask something u want to...
until now the page is only in german sry man!
seEn andL
Any new bios out yet ?
not that i know of...
the 7/16 MODDED bios solved all my vcore problems
cant get more than 2,67 vdimm...
man that suxxx more than anything i got fresh bh-6 chips and now i :banana: :banana: :banana: :banana:ed up!
i tried 6 different bioses from 14.5 to 16.7 and everytime now i got this vdimm voltage prob....
i ll get rid of it (maybe say so?!) so i ll go for the dfi board soOn well then i ll have to test some moa my chips....
seEn andL
PS: sry 4 my english m8s :D
And i can only get 1.7vcore with the modded bios, i need more lol
the modded bios didnt work for me until i did a complete CLEAR CMOS with the jumper. after flashing it:
-power off the psu
-change jumper
-wait 2 minutes
-put jumper in place and turn on
until i did all of this, i had vcore, vdimm and htt problems... now im clean
hope this helps
You should always to those steps after any bios flash.Quote:
-power off the psu
-change jumper
-wait 2 minutes
hope this helps
Well i got my new board and have been testing it out with some OCZ 3700EB 2x512 and this sucks!
I cant get the board stable with a FSB higher then 260x8 or 9 multi. Using cas 3,3,8,3 timings with a vdimm of 3.1v. I've even tried using 3,4,8,4 just to see for kicks and nope.
The highest HTT i can get is the same i could before with some corsair BH-5 at 308 somewhat stable.. 3d benchable and looked prime stable but it will reset outa nowhere. 310 wants to run but i'll get a blue screen durring 3dmark..
I've been using only the 5/14 bios since they were my fav last time..
No i believe my CPU 3400+ C0 is holding me back since it cant do 2500MHz on this board like it could on the old 150 chaintech with 1.7v.. But i was really hoping for like 270+ x9 with this ram.. Has anyone got over 267FSB?
yea i can go 285*9, 1*1 ratio and 4*HT prime stable. But i get a better score using 265*10.
i have a similar problem. my cpu would run prime stable @ 2400mhz on a MSI k8n neo plat. in this board can get only to 2300mhz. i guess this board does not like c0 chips much...Quote:
with CG chips i have never heard cpu OC complaints before
cheers
