I'm thinking of running OCZ PC4400 Dual Channel Gold Series Limited Edition EL-DDR CAS3.0 with this board with an FX-53 and X800XT. Good or bad move?
i think this M/B don't like hynix chips.
Choose corsair 3200 LLPT 1.2 2X512mo.
it's a Good choice.
Won't that limit possible FSB speeds?
Point seen. :p:Quote:
Originally posted by µnrealneo²
This is Xtremesystems, now, would he recommend it if it didnt like high fsb paired with this mobo? :D
I trust you, your in the UK (not far from me). I don't trust all these Americans :stick:
J/k :D
Users of GA K8NSNXP-S939, which is the best BIOS for oc: F2 or F3?
F3Quote:
what sorts of BH5 ? 3500 ?Quote:
Originally posted by pkrew
I know of two others using this board and have gotten around 265 3d stable with their bh-5
I'll have to ask, I think one was some corsair, not sure the model number. My lvl2 works as well
it will be interresting to know wich BH5 work good on the giga.
2x256 OCZ 3500 BH5 Runs 3D 264/5
2x256 Twinmoss BH5 reported 265
2x256 lvl2 stable to 260
2x512 lvl2 stable to 250
I have my Mushkin LevelII 3500 running 3D03 at 264 right now.
2-2-2-10 timings at 3.57V.
Still testing
OPP
Oc rookie , what's the PC number of each ram ? 3200 3500 ?
Now if I can just Overclock this CPU without blowing up the mobo I'll be in the books:D
OPP
Make that 266 3d03 proofed:D
OPP
:toast:
All the stable speeds posted are 3500 rated sticks. The Twinmoss I do not know the speed rating. I would imagine they are 32 or 35.
show us the 939's power OPP :)
Great job OPP :toast:Quote:
OPP
Thanks oc-rookie :toast:
apparently the gigabyte loves only 3500 BH5 , it's strange but very very interresting .:banana:
Thanks oc-rookie ;)
I'll try my KHX pc3200 on it and see what happens
yes , very good idea Pkrew , single or dble sided ?
i tried both KHX3200 and none works stable after 210 mhz neither 240 mhz on mine. :(
Well, i just ordered this board because i had no locks on my A8V. I'm expecting it tomorrow and am going to be testing it with just air cooling with 1 gb mushkin lvl II, 1gb 3200 Corsair LLPro, 1gb 3700 EB's, and a 256 mb pair of OCZ Limited Edition bh-5 that OC'd like MAD in my 754 setup. I also was lucky enough to score a Sappire X800 XT, which showed up a day early (today) :smileysex . Is the VDimm mod the same on this board as the K8N pro? I don't really want to do the 3.3 volt ATX bridge to the dimm because when i had my EB's much over 3 volts they would get burning hot. The minimum i think i could run with the bridge mod would be 3.2 volts or so....good for bh-5/ch-5, but too hot for the EB's imho.
stasiu if you sold a wire of floppy layer about 10 inches 25 cm you'll have Vio-0,2v with the bridge mod , if you want less try a longer wire or try with VR about 5 ohms , i think it works.
I confirm OCZ 3500 LE BH5 2x256, 265/266 stable for 3D @ 2,2,2,11
thx a lot ojdr ;) and congrats.
your M/B is not dead ? , i think i don't understand. :confused:
