Hello, Try using Nvidia Inspector to bump volts and you will get an increase with AB. Just be careful using/with good cooling. I can go to at least 1.4vgpu with my 580ltng. Also multimeter is your friend.
you can't be that sure, since the fact happens to me. EVGA DID TURN ME BACK THE SAME FAULTY GTX580 that i sent to them as RMA. either u believe it or not. it was the same one, the same problem, the same package! The dealer give me back the whole money, purposly kill the 580 and send it back for the second time for RMA. after that they give him a new one.
So what should I trust for reading voltages, Afterburner of GPU-Z/AIDA64? Afterburner shows .08V higher than GPU-Z.
You should only trust DMM. :D (with fresh batteries)
is it inspector more accurate than afterburner to increase volts ? or the same ?
is the just the same
Asus ROG Matrix
Default Voltage
950Core 1250Memory
I love this card
Look cool and strong HS
Full Set ROG :D
http://imageshack.us/photo/my-images/153/3d11950.jpg
that's default voltage and core speed?
950mhz with stock v .. is pretty GOOD! nice deal ;)
hello
need an opinion here.
what is the best choice
a reference EVGA GTX580 with EK waterblock, or an Asus GTX580 DCUII
both at the same price for example.
you can resell the dcu2 alot higher
Would depend if you watercool and want the card watercooled - I could have bought a DCuII but IMO they're no better than a reference card unless you're subzero cooling and I wanted it WC so the choice was easy. By the time I resell either card would be worth perhaps $100 anyway so I could care less what the resale value is - blocks never fetch much used so once you WC a component you're kinda committed to keep it awhile. If you only keep components a short time and resale matters to you then yeah, DCuII would be the better choice.
ya.
thanks
Anyway, I ended up with the evga with block
have advantages in temps and possibly in the OC.
and how I intend to do SLI, so takes up less slots and helps in temperatures later.
And it looks way better ;)
So after getting my vanilla evga GTX 580 a few days back, I have been trying to overclock, and with decent system airflow along with low ambient temps, I have tested upto 950/1900/4200 with voltage @ 1.15v and load temps never going over 74C. My question was what are safe 24/7 voltages running this card on its stock heatsink (I will redo the tim today or tomo), and can I go higher, cause right now I'm limited by the cards bios (I cant select any voltage over 1.15v), the above clocks are not 100% stable and I think if the voltage was a notch higher and the clocks could be 100% stable.
Everything's on air within a tiny case:
http://img844.imageshack.us/img844/8066/tri4.jpg
http://i1097.photobucket.com/albums/.../3dm11_tri.jpg
Sorry didn't see this until today.
I have an ln2 pot attached to this card for 1.3+vc. On my Lightening, using the software NI in combo with AB, so far not very cold (-75~-90c), I run benches at 1200+ like yourself and many others I've seen here. Start at 1.36~1.38vc and 1.4vc will hit on my MM under high load.
